Puncture hole on top of slideout
I have a 2016 320 BHDS. Today as I was blowing off the dinette slideout, I found a small hole about the size of a nickel that appears to have just torn through the membrane. I bought some eternabond tape to fix it but I'm not 100% sure on what I should use to prep the surface before the application. Someone mentioned denatured alcohol? Also does anyone know if the slideouts in these units use azdel like the sides do? I don't think a lot of water got in and don't see any leaks but Im trying to make sure I fix it right so we don't have issues down the road.
Thank you
Bob
2015 Dodge RAM 1500 Laramie w/ 4 Corner Air Suspension, 3.92 gears, 32 gal fuel tank, integrated brake controller
2016 Coachman Freedom Express Liberty Edition 320 BHDS
