Originally Posted by NMWildcat
Take lots of pictures, call your insurance company. Ensure it is protected from the elements until the adjuster looks at it unless insurance says different. They may adjust it with just pictures.
For permanent fix if you do not want to go through insurance, just use Eternabond.
X2
Contact your insurance (before permanently covering the punctures) and/or the insurance of the place it is parked if seasonal/permanent/storage.
Clean well (photos show your roof needs cleaned anyway) and then use Eternabond.
Once you install Eternabond correctly, you won't be able to remove it so use Gorilla tape or something that will keep the rain out until you get approval to repair.
Flex Tape (the stuff as seen on TV) indicates on their packaging it is not intended for permanent repairs.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
