Old 05-24-2020, 11:22 PM   #1
Question on low point drain ports
Hello, first time poster and apologies if this is the wrong location for my question (I own a 2017 Apex Nano 185BH).
I noticed that there were two low point drain ports. I could recognize one as the drain port for the fresh water tank since it was right underneath it.
The second one, I am having difficulty with. It is located underneath the general sink area. Any idea what this one is for?
Thanks!
vaarta is offline   Reply With Quote
Old 05-24-2020, 11:32 PM   #2
There are usually two low point drains, one red for hot and one blue for cold. They can either have caps on the ends or some have a valve on the end. SOME have the valve inside the trailer and just a hose hanging out underneath. For an Apex Nano, I'd bet on just plugs. You can see my plugs in this pic (not very well, though):
Name:	Low Point Drains and FW Tank Drains.jpg
In addition there should be a FW tank overflow, it could be any color, but is usually white.
Then you may or may not have a FW drain hose. Most FW drains are either just a plug or have a valve installed similar to this one, although there are some other styles:
Name:   RV drain valve.jpg
My FW tank had the plug, located right between the axles. I installed an elbow and some PEX and brought it out to a valve like above. You can see it in the first pic; I painted it black and it pretty much disappears into the rest of the plumbing underneath.
2011 Traverse LT, 3.6L, FWD
Old 06-16-2020, 04:54 PM   #3
Attachment 229822
Attachment 229823
What was your source for the above valve? I want to switch mine from the dumb plugs to a valve. Thanks.
*22' Rockwood minilite 2509s
*Chevy 2500HD
Alloutdrs1 is offline   Reply With Quote
Old 06-16-2020, 05:48 PM   #4
you may have 4 'drains'. it is key to determine if they have caps / valves on them or if they are open and the end.
here are the 4 that you might have and their typical colors:
fresh water tank overflow drain - white with an open end
fresh water tank drain - may be blue or white with a cap / valve
cold low point drain - blue with a cap / valve
hot low point drain - red with a cap / valve
the two low point drains with generally be right next to each other.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
drain
