Old 10-12-2017, 02:43 PM   #1
Chaplain Kent's Avatar
Radio Will Not Turn On
I took out the radio to add an AM antenna, an easy project when I found that the antenna was hooked up to be FM only. I made a simple AM looped wire antenna wired into an FM antenna and soldered onto an RCA plug. This worked great until I put the radio back in and it would not turn on. I tried the reset button, checked there is 12V power, fuse is good, switched back to old antenna set-up, but still radio does not turn on.
Who is manufacture of this radio so I can trouble shoot further?
Chummy V
2014 Forester 2501TS
Ford E-450
Chaplain Kent is offline   Reply With Quote
Old 10-14-2017, 08:05 AM   #2
SeaDog's Avatar
to get an answer you need to add a little more information like name on radio to find Mfg
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-14-2017, 08:38 AM   #3
The info should be there on the radio itself (may have to take it out again) and a simple Google search might give you some answers.
TheWolfPaq82 is offline   Reply With Quote
radio
