Old 07-06-2016, 07:45 PM   #1
MurphyIRE's Avatar
refrigerator on gas
Tested the frig on gas, It worked for a while, but it was constantly clicking. That tank went dry an I switched over to the other tank. It made the clicking sound but the check light kept coming on and the fridge stopped cooling switched to 12 v on it worked. I could hear the clicking noise but not at the same rate as the gas clicking sound.
Thoughts??
Sean & Susan
Proud Parents of
Two US Marines
2016 Chapparal Lite 29MKS
2010 F-250 6.4L Diesel
MurphyIRE is offline   Reply With Quote
Old 07-06-2016, 07:48 PM   #2
TURBS's Avatar
Air in the line and or you opened the tank valve to fast.
Shut tank valve off and SLOWLY turn it back on.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "10"
Old 07-06-2016, 08:00 PM   #3
davel1971's Avatar
it will only try a couple times to light then it will give up. Light your stove burner to clear air from the line. Turn fridge off then back on to reset. Might have to cycle again if it doesn't light the first time.
David & Lynn
2014 Coachmen Chaparral Signature 327 RLKS
2016 Ford F350 Lariat CC Dually
davel1971 is offline   Reply With Quote
Old 07-06-2016, 08:10 PM   #4
rattleNsmoke's Avatar
Once switched to 110v ac, you are not using the propane system and should not hear anymore clicking of the gas igniter. Double check that both tanks are not empty. It happens. Good advice the others have given If there is available propane, bleed the air out.
2010 Cedar Creek 5th Wheel 34SATS "The Beast"
2006 Ford F350 Lariat 6.0L Diesel
2003 Harley Heritage Softail "Hogzilla"
1986 Marriage to "Wifey" (patience of a saint)
rattleNsmoke is offline   Reply With Quote
Old 07-06-2016, 08:30 PM   #5
Mr. Dan's Avatar
Originally Posted by MurphyIRE View Post
.... switched to 12 v on it worked.
I can't get this sentence to fit in my brain. If you truly switched to 12 v, it means you have a 3-way refrigerator, not a propane/110v AC fridge. Did you mean to say 'switched to 120v?
Mr. Dan is offline   Reply With Quote
Old 07-07-2016, 12:57 PM   #6
Had same clicking/check light problem when trying to run fridge on gas. Dealer said air in line, always light one stove burner first as it is a much bigger draw on the gas and will clear the lines...worked like a charm.
stellaandspike is offline   Reply With Quote
Old 07-08-2016, 10:14 AM   #7
Insert witty title here
X2.
Light a stove burner first to get all the air out of the line, then switch on the fridge.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
timfromma is offline   Reply With Quote
Old 07-12-2016, 12:50 PM   #8
MurphyIRE's Avatar
Thanks the suggestions. We did run out on 1st tank. Switched over and it worked. The dealership is going to check the setting for altitude.
12v (DC) and propane
Sean & Susan
Proud Parents of
Two US Marines
fridge, gas
