Old 08-14-2023, 10:41 AM   #1
Replace panel switch FE UL 192RBS
I need to replace the water heater panel switch because the LED is burned out, and I sometimes forget to turn it off. No part number on the switch. I think it is a Sigma switch (blue LED). Not having any luck with internet searches. Does anyone know where I can get a replacement? Thanks.
Jon1967 is offline   Reply With Quote
Old 08-14-2023, 12:37 PM   #2
bubbles's Avatar
If it's the WH electric switch probably a SPST (single pole/single throw) blue illuminated rocker switch (energizes a relay). The size is pretty much standard across the industry but the bezel may be a different shape.
Old 08-14-2023, 01:05 PM   #3
that's a correct description.....just don't know where I can get one the specific size and I need
Old 08-14-2023, 07:42 PM   #4
bubbles's Avatar
I think your panel is a KIB panel and therefore the switch is a KIB SPST illuminated blue rocker switch. I think.
Old 08-14-2023, 08:06 PM   #5
fipntdot's Avatar
Since those switches trigger a relay, are they interchangeable? Would it be possible to switch the overhead light switch with the other switch? Its not like I need a lighted switch to tell me the lights are on. Just speculating because on mine, all of the switches are on the same panel. your's might be different.
22 Freedom Express 257BHS
19 F-150 3.5 Max-Tow
fipntdot is offline   Reply With Quote
panel, switch
