Old 05-10-2018, 05:35 PM   #1
Sanitizing Water System
I have a 2017 Chaparral 392 MBL....FINALLY the weather is better allowing us to de-winterize. I went out today to “sanitize” our system using some bleach/water mix. Problem is, how the heck do you get it in the system??? It’s not like my old trailer where you could just pour it down the big fill hole....the hose hooks up to the panel!!!
Gsxrgrizz is offline   Reply With Quote
Old 05-10-2018, 05:41 PM   #2
Flybob's Avatar
Run some water in the FW tank via the panel then disconnect hose from water supply and let water drain from hose. Then pour the bleach into the hose and reconnect to water supply and continue to fill FW tank.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Flybob is online now   Reply With Quote
Old 05-16-2018, 04:15 AM   #3
Makes sense, I was hoping there was a slightly easier way but that will work...thanks!!!
Old 05-16-2018, 06:29 AM   #4
Cut a 2' section of old garden hose or go to the hardware store and by a section of plastic hose smaller than the inlet for your tank. Use a funnel.
Rusty
lcv800 is offline   Reply With Quote
Old 05-16-2018, 07:30 AM   #5
Rusty
That’s the problem, I don’t have an “inlet” like you are suggesting that I can put a hose into. I only have a fitting on my panel where the hose screws into
Old 05-16-2018, 07:52 AM   #6
Mr. Dan's Avatar
Flybob has the solution to your problem.
Mr. Dan is online now   Reply With Quote
Old 05-16-2018, 08:01 AM   #7
Adding bleach to the hose, as mentioned, is the most common way.
A friend of mine made a way to ingest the bleach into the system using a garden hose chemical sprayer. They added a short garden hose hose to the outlet end of the sprayer, (which was then hooked to the city/fill port on the side of the rig) added bleach to the container, connected a garden hose to the inlet side of the sprayer and viola!, as the water entered the fresh tank passing through the sprayer, so did the bleach.
Old 05-27-2018, 10:15 AM   #8
That’s actually a pretty cool idea!!!
water
