Old 04-14-2018, 01:00 PM   #1
Slide maintenance
My wife and I have a Coachmen Catalina Legacy 263rls.
What maintenance is needed to assure that slide continues to work properly. Do you grease the slide, oil or other. This is a new unit bought last year. We are taking a extended trip this summer.
pastorlarry is offline   Reply With Quote
Old 04-14-2018, 02:14 PM   #2
glsimms's Avatar
I use a spray lube on the slide mechanism and a spray lube for the slide seals once a year.....
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
glsimms is offline   Reply With Quote
Old 04-14-2018, 02:17 PM   #3
WD-40 or something else?
Old 04-14-2018, 02:23 PM   #4
Use a dry lube. WD-40 does make a dry lube (specialist brand) and thats what i use but it's not the regular stuff. You don't want to spray a lube on the mechanism that would attract dirt and debris.
Use a good rubber lube on the seals.
I use 303 protectant.
Days Camped: '18=51 '19=58 '20=110 '21=94
Old 06-13-2018, 07:09 PM   #5
Can you run 3800 fps?
On the Slide...
Yeah, I waste money. Ounce of prevention... Every time we take the rig out, I lube the steps, slide rails and gears and stabilizers with WD40. On the seals for the slide outside, I use Camco Slide seal lube. Inside seal twice a season. Yeah, it might be too much, but lube is cheap compared to repairs or replacements.
SniperDroid is offline   Reply With Quote
Old 06-16-2018, 01:01 AM   #6
There is a lubricant made specifically for slideouts. I've seen it at my local Walmart. It comes in a spray can.
2019 Silverado LTZ 1500 6.2L 10 Speed 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2016 Silverado LTZ 1500 5.3L 6 Speed 3.42
2015 Jeep Wrangler Unlimited Rubicon 3.6L 4.10
2020 KZ 130RBSE
AlaskaErik is offline   Reply With Quote
Old 06-16-2018, 02:20 AM   #7
ramit315's Avatar
I never use regular WD-40 for slides. There are specific slide lubes for RV's. There are a bunch on Amazon with reviews.
2018 Ford F-450 DRW
2017 Sandpiper 379FLOK
ramit315 is offline   Reply With Quote
Old 06-16-2018, 03:24 PM   #8
This is also a good time to determine what kind of slide mechanism you have and how to manually retract it should it fail when you're ready to break camp. There are lots of YouTube videos that cover the different types of slides. For my particular slide, I need a couple of precut 2x4s to "lock" my slide in place once it's been manually retracted. That's not something I want to have to deal with while boondocking in the middle of nowhere.
2020 KZ 130RBSE
maintenance, slide
