Old 02-20-2024, 01:56 PM   #1
Slider Tips Out!
Hi guys I have a 23 Brookstone 398mbl. Every time I go around a left-hand turn the big kitchen slide tips out at least a foot or two. I went back to the dealer and had them check everything over. Their response was everything was within spec so they will have to get with Forest River for a solution. Forest Rivers solution is to give me a set of manual slide locks. I paid over 80k for this fifth wheel and am a little upset (to put it mildly) over this situation! Am I overreacting or is this really "industry standard" as Forest Rivers GM is stating to me?
suprarider565 is offline   Reply With Quote
Old 02-20-2024, 04:52 PM   #2
That doesn’t sound normal. What type of slide mechanism do you have?
Cross-threading works better than blue loctite.
Capacitor is offline   Reply With Quote
Old 02-20-2024, 06:45 PM   #3
I believe it's a electric gear driven so rack n pinion I'm guessing?
Old 02-20-2024, 07:12 PM   #4
Oaklevel's Avatar
The older units had a guard (stick) that you put on top of the slide when closed to keep the slide closed while driving.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 02-24-2024, 01:43 PM   #5
That is totally not normal. We have a chaparral 360ibl which is a similar config.
The dinette slide should not budge when retracted. The through-frame slide mechanism holds the bottom of the slide tight to the wall. If the opening at the top is sized correctly the slide could possibly move 1/2 out at the top(wild guess based on the opening in the wall) but it would take a lot of force to make the heavy slide room tip outward.
Something is not right with either:
1-slide mechanism
2-the floor flange that the slide rides on
3-the wall opening vs slide box fit spacing is too big
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
chaps2018 is offline   Reply With Quote
Old 02-24-2024, 02:54 PM   #6
That's what the slide locks are that the OP mentioned.
Iwritecode is offline   Reply With Quote
Old 02-24-2024, 07:19 PM   #7
Call the manufacturer of the slide mechanism direct and see what they say. I quit dealing with my dealer on problems three months after we bought the trailer. Their customer service after the sale was awful. I have dealt direct with manufacturers of both the trailer (East to West) and the components (Furrion and Dometic) with very good results.
Jim
East-West 34 Alta 2850 KRL
2023 Expedition Platinum
jjscsix is offline   Reply With Quote
Old 02-24-2024, 08:46 PM   #8
Oaklevel's Avatar
Correct. They were a normal part of keeping a slide in.
1966 Mustang GT
1986 Mustang SVO
Old 02-24-2024, 09:46 PM   #9
I have a large slide out in my 2017 toy hauler and never had this issue. They are handing you a line of **** just to get you off the phone.
Odyknuck is offline   Reply With Quote
slide
