08-24-2020, 11:00 AM
Small light to illuminate control panel
Hello.
Our trailer has the control panel right near the entry door. Needless to say, if we are coming in at night, it is hard to see which rocker switch controls what.
Has anyone added a small 12 volt light above the control panel to illuminate the rocker switches (in a dim fashion)? Pics and possible links would be nice too.
Thank you.
08-24-2020, 11:51 AM
What about using a puck light?
08-24-2020, 12:19 PM
Would a small LED license plate light work? We have only had our fifth wheel for a couple weeks and have notice the same thing. We do have a small hall light that just lights the stairs but the panel itself is hard to see. We also don’t like leaving lights on when we are out and about so know where your coming from. We are thinking of how to address this as well.
08-24-2020, 12:37 PM
KFinn... that's the 'concept' I'm hoping to find a solution for... something like a license place light... small sconce light.. something small that would just illuminate that area and can be turned off when we're done with it.
08-24-2020, 04:22 PM
I have been considering something like this for awhile and what I have come up with is using a RV stair well light that illuminates the control panel without blinding in you in the process.
Something like this....
Https://www.amazon.com/Dream-Lightin...8302746&sr=8-3
Also you could install a dimmer inline with it as well.
https://www.amazon.com/BZONE-12-24V-...%2C176&sr=8-34
Jim & Evelyn Tatum
2023 Columbus River Ranch 391MK
2022 Dodge Ram 3500 Big Horn Diesel
Nights Camped 2023 = 30
Nights Camped 2022 = 40
08-24-2020, 11:14 PM
Mine is the same but after unscrewing the panel I found that it was already translucent where the words are. I put led lighting behind it instead and added a switch to use it to turn the backlight off/on.
Hopefully that helps and yours is the same.
08-25-2020, 05:33 AM
That would work amazing I will have to check mine out. There is a blank spot for another switch.
08-25-2020, 05:59 AM
If you don't want to hard wire in a light, consider a battery operated led light. You can get them that usb recharge or take standard batteries. They use a stick on magnet to hold them in place.
Lots of models to choose from.... here's one https://smile.amazon.com/Homelife-Wi...%2C205&sr=1-31
2015 Dynamax REV 24TB class C
08-25-2020, 12:28 PM
On my RS320 the panel is inside a cabinet in front of the door. I added a magnetic switch to the door the put a 12v led light strip along the top inside the door. Open the door the legs come on, close the door they go off.
08-25-2020, 01:25 PM
Originally Posted by jtatum65
that is good idea!!!
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
08-25-2020, 05:24 PM
I have been using this style of light for a couple of years. Motion sensor and quick easy install. This is the way to go.
08-25-2020, 05:30 PM
I put these on my license plate. It could work for what you are thinking and be pretty small if you don't want to back light it.
https://www.amazon.com/dp/B077Z6WQ6Q..._sdzrFbRPGFJSV
08-25-2020, 10:58 PM
I never go out of the house (or RV) without a flashlight. Makes no difference if it's day or night, what time I plan to be home, etc. If nothing else, a small light clipped to my key ring. Having one saved my life once many years ago. They also come in handy for finding things like unraveling DW's chicken wire from the lawn mower blades. I highly recommend the practice.
2018 Coachmen Leprachaun 210RS with DW, Nanuq the Samoyd puppy and the cat.
08-26-2020, 06:41 AM
Dbledan: That's something interesting to me. May just look into it and put it on a switch to turn on/off when needed. Thank you.
Adrian: totally agree with your practice. This is more if I'm at the campground outside by the fire and only have the accent lights on in the rv (they are still not bright enough to light up the control panel) or when we wake up in the middle of the night and try to find that one light switch.
Thank you everyone.
08-26-2020, 10:01 AM
We had the same issue with our fifth wheel ... our panel is actually behind a cupboard door.
Ordered this from amazon and loved it so much that I've since ordered another for the ceiling of the master bedroom closet, as DH kept leaving the 12 volt ceiling light on.
https://www.amazon.ca/gp/product/B07...?ie=UTF8&psc=1
10-27-2020, 05:04 PM
panel light
We had the same issue so we put a battery powered light switch down low on the wall, right as you enter from outside. We put it low so that we can reach it from the steps outside to flip the switch. it's very bright and lights up the whole entryway area of the tt so plenty of light to see the control panel. I like the idea of the small license plate light so I'm going to look into that for right above the control panel. We have the led motion sensor lights all over our tt (in cabinets and we love them) but these didn't work for us in this application. We found that when we (or the dogs) moved at night that it triggered the light and it turned on. It was so bright that it was disturbing our sleep so we took it down. Just something to keep in mind, your mileage may vary.
Lisa and my furry kids - Dante, Capucine, Scout, and Riata
RIP - Cesare and Cincia
Chevy Express 3500 van
Palomino Solaire 251RBSS
Wherever you go, go with all your heart.
10-27-2020, 05:28 PM
https://www.harborfreight.com/200-lu...ght-64723.html
Unencumbered By The Thought Process
10-27-2020, 05:40 PM
We have the same problem. I think a courtesy light like this one below may do the trick. if there is an empty switch location I may just add a switch for it on the panel, or just find one with its own switch.
We have a toy hauler, and the problem is worse when entering from the garage as the switches for the room are a little further away. I GUESS IT WOULD MAKE TOO MUCH SENCE TO PUT THE SWITCH BY THE DOOR!!
https://www.amazon.com/LED-Convenien.../dp/B003QK5QKU
2021 FR XLR Nitro 35DK5
2019 F250 SRW 6.7 PS Diesel
11-15-2020, 12:50 PM
Defender of America
Mr Beams
Stuck a small motion activated Mr Beams light over the panel and it comes on when I open the door. I've usually got my hands full so automatic works great. And it turns off by itself which is also great because grandkids know how to turn lights on but can't seems to be able to turn them off.
Retired USAF
2021 Freedom Express 192RBS
2020 F150 STX 4X4 w/Coyote V8
Centerline TS WDH
11-15-2020, 05:03 PM
Perhaps one of these would work for you. Connect the LED light negative side to COM and NC terminal to ground. The switch will be open when the door is closed. It's the same type used for electric steps. It only has to sink about 100mw.
https://www.amazon.com/Directed-Elec...ag=googhydr-20
