Old 09-15-2017, 05:04 PM   #1
Michael k's Avatar
Smell throughout RV when emptying black water tank
Every time I empty the RV tank it smells through the whole RV is there something wrong that anybody had experience with? I don't have a problem when I flush it only when I empty the tank.
Michael k is offline   Reply With Quote
Old 09-16-2017, 01:31 PM   #2
I am having the exact same issue, except it also happens when I flush. I replaced the stock vent cover with a cyclone vent cover. I haven't used the camper yet since i installed it but will be using it for 5 days later next week. I hope someone posts a reason for it, it makes it extremely hard to be in the camper when this happens.
2017 Freedom Express 248 RBS
2017 F-250
loadtoad1a7 is offline   Reply With Quote
Old 12-04-2017, 12:53 PM   #3
I had the same issue on my 2014 Wildwood. also had one of those cyclone's on it. I was able to mostly fix the smell by completely cleaning out the black tank i had one of those sticks that you put in the toilet connected to a hose and completely power washed the inside of the tank out. That seemed to help quite a bit. I think i let the tank get too full and some of the paper got stuck up into the air vent pipe. At least this is my thinking. I had even flushed water down the air vent but that did not seem to help.
gouda272 is offline   Reply With Quote
Old 12-04-2017, 01:32 PM   #4
MilCop4523's Avatar
Try closing the roof vent to the bathroom before you dump the tank. for some reason fumes get pulled back into the washroom if its opened.
I always close mine and have found a difference - not sure why. I also added cyclones to the vent stacks which helped with the stench after stopping for the night when hauling.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 12-05-2017, 12:17 AM   #5
Are the gray water valves open?
sbpierce is offline   Reply With Quote
Old 12-05-2017, 05:08 PM   #6
I ended up putting 5 gallons of water and softener mix in mine with some pine-sol. Drove 8 hours to camp and than used the black tank flush and flushed the hell out of it. Now whenever i get done camping I make sure to flush until absolutely nothing comes out but clear water. I don't think the black tank flush does that great of a job without having to fill and empty the tank 4 to 5 times. Does anyone have a better solution to flushing the black tank without taking forever to do it? Before I get flames I only do this at a site with full hookups not at a dump station.
2017 F-250
Old 12-06-2017, 07:18 AM   #7
This happened to me when I forgot to close the gray water tank valves
Pjs63 is offline   Reply With Quote
black, black water, tank, water, water tank
