Old 03-04-2021, 12:33 PM   #21
Originally Posted by 80 Cruiser Rod View Post
I'm going back to my original question which hopefully will warrant a Yes or No answer. Let's Keep It Simple Stupid. With all due respect let me be the stupid one.
Do I have to stay with a RV thermostat if I want to replace mine?
I believe that the Dometic A/C unit uses a different thermostat wiring that requires modification of a standard thermostat to work. So it isn't necessarily an "RV" specific thermostat you need, but it is a type of thermostat that needs to be compatible with your Dometic A/C unit.
What about this:
https://www.rvpartscountry.com/New-B...xoCOjEQAvD_BwE
Also, if you read to the bottom of that link, it talks a little bit about the difference between Dometic digital control for the A/C, and standard analog thermostat control.
Then maybe using the app on your phone would give the visibility you would need.
NavyLCDR is offline   Reply With Quote
Old 03-04-2021, 01:42 PM   #22
80 Cruiser Rod's Avatar
Originally Posted by bubbles View Post
Simple answer; no. Complex answer; yes. Your Dometic stat is 3 wire digital and I don't think there is a commercial stat that will directly replace it. I think that's what I have read on this forum.
Thank you!
2020 Northern Spirit 1943RB
2017 Toyota Tundra SR5
80 Cruiser Rod is offline   Reply With Quote
Old 03-04-2021, 03:12 PM   #23
Simple answer is, Yes.
As Bubbles mentioned, without a lot of work and expense you're pretty much limited to a couple of Dometic RV thermostat models.
Gotta go campin!
Old 03-04-2021, 03:17 PM   #24
Got it, thank you.
thermostat
