Old 03-03-2021, 05:49 PM   #1
80 Cruiser Rod's Avatar
Thermostat Hard To Read
I'd like to change my thermostat in my camper. It's very small and very difficult to read. Do I need one specifically for RVs?
2020 Northern Spirit 1943RB
2017 Toyota Tundra SR5
80 Cruiser Rod is offline   Reply With Quote
Old 03-03-2021, 05:54 PM   #2
Just go to Amazon and type in 'RV Thermostats'. They have them for heat only, Heat and AC, Programmable, 12 V hard wired and battery operated all at various price points. If you have the AC controls on the AC roof unit then you just need a heat only one. They are very easy to install, I think it took me about 5 minutes to put in a heat/AC one. Make sure you note what terminals the wires are on your old one before taking it off. And make sure the wires don't fall back behind the wall.
2020 Flagstaff Micro Lite 22FBS
Old 03-03-2021, 05:58 PM   #3
Originally Posted by Wiscampsin View Post
Just go to Amazon and type in 'RV Thermostats'. They have them for heat only, Heat and AC, Programmable, hard wired and battery operated all at various price points. If you have the AC controls on the AC roof unit then you just need a heat only one. They are very easy to install, I think it took me about 5 minutes to put in a heat/AC one.
So I definitely need a RV Thermostat?
Old 03-03-2021, 06:09 PM   #4
Nope, Home Depot sells some that will work in an RV.
Some links for you:
Hunter Thermostat
https://www.forestriverforums.com/fo...de-181848.html
https://www.rv.net/forum/index.cfm/f...d/24108995.cfm
Old 03-03-2021, 08:09 PM   #5
Head Rambler
It depends on which thermostat you have now as to whether you can swap it for a residential thermostat.
If you will give us the make and model of the one you have now or post a picture of it we can tell you what you can do.
Gotta go campin!
Old 03-03-2021, 08:12 PM   #6
Well, first we would need to know what you want to control in your camper with the thermostat. Furnace only, air conditioner only, A/C and furnace, or A/C, heat pump, and furnace? Sorry, need more information.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 03-03-2021, 08:17 PM   #7
This is what I have replaced the standard RV thermostat for heat only with:
https://www.amazon.com/gp/product/B00QW2WXRS
They also make a horizontal version that is a little cheaper. What I like about this thermostat is that it has a programmable range. Most thermostats work on +/- 1 degree. I found that narrow range caused my furnace in my Geo Pro G17RK to cycle on and off too frequently at night. I set this thermostat for a 3 degree range. So, if I set it for 68 degrees, the furnace comes on at 65 degrees and stays on until 69 degrees. This is a temperature swing to me that is still comfortable, but also eliminates the on and off cycling.
NavyLCDR is online now   Reply With Quote
Old 03-03-2021, 09:52 PM   #8
It depends.
On my Skyline Koala and my current 2021 Coachmen FE 20SE, I only needed a Heat Only thermostat. With the Koala, I used a residential Hunter thermostat. For my current Coachmen trailer, I used a Honeywell PRO 1000 heat only, non-programmable thermostat.
My 2017 Jayco Jay Flight 23RB had a central heating/Air conditioning thermostat. For this one, I wanted to make sure the many wires went to the right place. So I bought a Coleman digital thermostat. When changing, I simply changed one wire at the time. That way, I couldn't mix up the wiring.
2021 Freedom Express 20SE (formerly 204RD)
2014 F150, 3.5L EB, 4x4 SuperCab. 8' Box, Max Tow and HD Pkg
Atlee is offline   Reply With Quote
Old 03-03-2021, 10:05 PM   #9
How about posting a photo of what you have now?
Old 03-04-2021, 07:45 AM   #10
Here it is. One note. The digital readout is not back lit all the time. This thermostat is not wired into the trailer's electrical system. It powered by a couple of AAA batteries. The back light will go off after a brief period.
Name:	01 Thermostat - Analog.jpg
ID:	248854   Click image for larger version
Name:	02 Analog Thermostat with Front Off.jpg
ID:	248855   Click image for larger version
Name:	03 Digital Honeywell PRO 1000 Heat Only Thermostat.jpg
ID:	248856   Click image for larger version
Name:	05a New Digital Honeywell Thermostat.jpg
Old 03-04-2021, 09:34 AM   #11
I'm not sure of the model but here is a picture.
Old 03-04-2021, 09:34 AM   #12
Heat and A/C
Old 03-04-2021, 09:36 AM   #13
Here it is.
Old 03-04-2021, 09:37 AM   #14
Thanks for Pirating my thread
Old 03-04-2021, 09:42 AM   #15
I thought NavyLCDR was asking me for a pic of my thermostat mod. Sorry.
Old 03-04-2021, 10:00 AM   #16
NP, hopefully both our questions will be answered.
Old 03-04-2021, 10:16 AM   #17
bubbles's Avatar
Here it is.
This is the one yours replaced. Direct swap out. Don't know if it would help your situation. It is also a Dometic and comes with the same selections you have now. There are different part numbers for what functions you now have.
Old 03-04-2021, 10:19 AM   #18
bubbles's Avatar
Additionally; yours is a capacitive touch stat and the other is a tactile button stat.
Old 03-04-2021, 11:58 AM   #19
I'm going back to my original question which hopefully will warrant a Yes or No answer. Let's Keep It Simple Stupid. With all due respect let me be the stupid one.
Do I have to stay with a RV thermostat if I want to replace mine?
Old 03-04-2021, 12:05 PM   #20
bubbles's Avatar
Simple answer; no. Complex answer; yes. Your Dometic stat is 3 wire digital and I don't think there is a commercial stat that will directly replace it. I think that's what I have read on this forum.
thermostat
