Old 10-08-2020, 12:11 PM   #1
80 Cruiser Rod's Avatar
Water Heater Questions
I have a Dometic Atwood water heater in my camper. After reading some of the manual I understand it has an aluminum and zinc clad tank. My 1st question is: Should I have an Anode Rod in this tank? My 2nd questions is: The drain plug takes a 15/16" socket. What size should I look for and what length of rod?
2020 Northern Spirit 1943RB
2017 Toyota Tundra SR5
80 Cruiser Rod is offline   Reply With Quote
Old 10-08-2020, 12:23 PM   #2
Atwood water heaters with aluminum tanks do not have an anode rod.
The drain plug is usually plastic but not always if someone replaced it.
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 10-08-2020, 01:03 PM   #3
wmtire's Avatar
X2. Atwood/Dometic brand aluminum tank type water heaters do not need an anode.
It is the Suburban brand with their porcelain lined steel tanks that use an anode rod.
2011 Flagstaff 831 RLBSS
I often say to myself, "I can't believe that cloning machine worked."
Old 10-08-2020, 02:05 PM   #4
So the aluminum and zinc clad tank is the anode? If that is correct I would imagine it would degrade and need to be replaced eventually?
Old 10-08-2020, 02:30 PM   #5
Mr. Dan's Avatar
No... the aluminum and zinc clad tank requires no anode at all.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 108; booked = 0
heater, water, water heater
