Old 05-18-2021, 07:20 PM   #41
MOJO380's Avatar
Took table legs off and installed folding shelf brackets for a fold down table. Have 2 folding chairs so wife and I can eat by the window.
MOJO380 is offline   Reply With Quote
Old 05-19-2021, 06:41 AM   #42
That’s nice. My table is in the basement of my house we use TV trays. Did you use regular hardware for a small folding shelf? Do you have picks of underneath?
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 05-19-2021, 06:44 AM   #43
I had thought about doing a bar top project something like this with a folding top and we would pull up folding chairs to sit at and look out window.
2005 Honda VTX 1300
Old 05-19-2021, 08:29 AM   #44
MOJO380's Avatar
I used 1x3 poplar boards screwed to the wall studs with drywall screws. Then attached the 20" folding shelf brackets to those. I positioned the top on brackets and marked holes and attached with screws that came with table. I decided to use a 1" dowel rod with rubber end caps to hold up the outer edge of table when using. It has worked out great for us. Adds some counter space when working in kitchen area
Old 05-19-2021, 10:59 AM   #45
Awesome
2005 Honda VTX 1300
Old 06-27-2021, 12:00 PM   #46
ID:	257937Click image for larger version
ID:	257938Click image for larger version
Reclaimed empty space for shoes!!!
2005 Honda VTX 1300
Old 11-06-2021, 02:56 PM   #47
Finally added shutoff valves on low points, and change the shutoff on fresh water to bigger one. Click image for larger version
ID:	265369Click image for larger version
2005 Honda VTX 1300
Old 04-18-2022, 07:08 PM   #48
Table mod. Click image for larger version
ID:	271725Click image for larger version
ID:	271726Click image for larger version
ID:	271727Click image for larger version
2005 Honda VTX 1300
Old 07-30-2022, 06:51 PM   #49
ID:	277200Click image for larger version
ID:	277201Click image for larger version
ID:	277202Click image for larger version
ID:	277203Click image for larger version
ID:	277204Click image for larger version
ID:	277205Click image for larger version
ID:	277206Click image for larger version
Fixed tire up linoleum in garage section of toyhauler.
2005 Honda VTX 1300
Old 08-01-2022, 07:59 PM   #50
Finished trimmed out
2005 Honda VTX 1300
Old 12-01-2022, 07:24 AM   #51
Fireplace install. Bought new electric fireplace for TH. Built cabinet to house it. Just need finishing touches. Then I will install in the back of TH. Click image for larger version
ID:	281929Click image for larger version
ID:	281930Click image for larger version
ID:	281931Click image for larger version
ID:	281932Click image for larger version
ID:	281933Click image for larger version
ID:	281934Click image for larger version
2005 Honda VTX 1300
Old 12-01-2022, 09:40 PM   #52
ID:	281957Click image for larger version
Hardware and clasp attached. Just need to install now
2005 Honda VTX 1300
Old 12-02-2022, 06:00 PM   #53
ID:	281980Click image for larger version
ID:	281981Click image for larger version
ID:	281982Click image for larger version
Installed
2005 Honda VTX 1300
Old 12-02-2022, 06:00 PM   #54
2005 Honda VTX 1300
Old 01-27-2023, 02:47 PM   #55
Added baskets above bed to hold items and make it look nicer
2005 Honda VTX 1300
Old 02-20-2023, 10:19 PM   #56
ID:	284105Click image for larger version
Replaced cheap faucet, and will be replacing plastic sink, once it is delivered. Going with stainless single bowl. Click image for larger version
2005 Honda VTX 1300
Old 02-25-2023, 12:31 AM   #57
New sink.
2005 Honda VTX 1300
Old 02-26-2023, 05:23 PM   #58
Sink finished and installed no leaks!
2005 Honda VTX 1300
Old 03-19-2023, 04:16 PM   #59
ID:	284930Click image for larger version
Replaced the seal on the rear garage door. I got tired of the I’ll designed seal that manufacture installed. With movement it keep coming off.
2005 Honda VTX 1300
Old 05-31-2023, 08:18 PM   #60
Installed spice racks. Makes them handy without digging into cabinets. Click image for larger version
ID:	288008Click image for larger version
2005 Honda VTX 1300
puma, toy hauler
