Repaired 298fqu
I had a local body shop repair the ramp door and it is now stronger than original, and even looks better.
I replaced the converter (because a mouse built a nest on the old one causing it to overheat), installed a set of Goodyear Endurance load range E tires, and packed the wheel bearings.
Everything still works, looks decent, and it suits our needs, so we have decided to keep it.
May have the front cap painted with automotive grade clear-coat to match the repaired ramp door and prolong the fiberglass cap since it's still in good condition.
Thanks for the response.
