Originally Posted by CedarCreekWoody
I'm just speculating here as my TT does not have a generator, but wouldn't it be best to run both inputs through the EMS? Couldnt a generator malfunction and be off in voltage or cycles, enough to cause damage?
Progressive Industries recommends to install a hardwired EMS prior to the transfer switch. The reason for this is most RV generators already have built-in voltage and frequency protection. If the EMS is installed after the transfer switch, this leaves the transfer switch vulnerable to power problems.
