Toyhauler ramp...
OK all, I removed my ramp from my 27SBU to repair the damage. I removed the exterior channels and to my surprise there was more damage than first thought as the aluminum bracing where the hinges mount, two 1" square tubing, were broken both ends. There was water damage to the extremely thin plywood deck. This I cut back 11" to expose any and all damage? Have taken the framework to a local machine shop to be TIG welded. The original TIG welds were deplorable shoddy work. I will replaced the bottom plywood with 1/8" sheet aluminum, refasten the channels, then will sandwich the hinge area with 1/8" diamond plate inside and out. This may seem to be exreme but will not have more ramp issues in the future. MTG
