Originally Posted by rjw54
I have a cardinal 3350 2018 and sat input doesnt work due to splitters inside body of fifth wheel. Anyone having this issue? FR says they dont know what antenna will work.
Lots of folks have that problem. Trick is to find the splitters and either remove them and have a straight shot from dish to receiver, or if it's only one you want to keep, replace it with a high quality power pass-through splitter. Sometimes that will work.
Usually splitters are behind the inside coax wall mount or the antennae boost panel. But I have found them behind drawers, in cubbies, behind access panels. Really just about anywhere. Just takes some investigation.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
