11-28-2020, 10:28 AM
Swap RCA to HDMI connection???
Has anyone done or attempted this? I tried to pull on the RCA cables where they came out of the wall hoping that I can use them as a pull cable, but it feels like they’re fastened in. -Any tricks?
- Is there a possibility of finding prints/drawings for my camper?
11-28-2020, 10:34 AM
hdmi has video , rca sound only . you need both .so add hdmi cable.
11-28-2020, 10:49 AM
Sounds like he is talking about RCA red/wht/ (audio) yellow (composite video).
11-28-2020, 10:59 AM
all of my cables go to the stereo . out to outside tv jack and to rear outside connections for cable or satellite. or use blutooth if stereo is capable. you have to buy a seperate cord for phone to stereo for movies from phone .
11-28-2020, 11:01 AM
All Around Hoser
RCA connectors with left right audio (red/whir) and video (yellow)
11-28-2020, 11:11 AM
There are no wiring schematics for any RV I know of.
The easiest thing to do is to just add an HDMI cable by the best route available. It will just take some investigation by you on how to do that for your unit.
I have seen and done it many ways. Through cubbies, behind cabinets, out the bottom of the RV and back up through the numerous cutouts for pipes and wires.
Or pay a bit and go the wireless HDMI route.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
11-28-2020, 11:27 AM
Georgia Rally Coordinator
There is a HDMI adapter cable that you can connect your RCA cables to. I had to do this as when they replaced my tv I had no connections for the RCA cabls on the back of my new tv. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
11-28-2020, 11:59 AM
My RCA cable tips broke off when we forgot to strap down the TV. I own an audio video cabling company, but am hesitant to go crazy on this camper since it seems so fragile and I would have to remove panels.
11-28-2020, 12:08 PM
Have you pulled the radio/cd/dvd player to see if it even has an HDMI outlet built in?
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
11-28-2020, 12:25 PM
Sure haven’t. I assumed it did since this 2020 but I guess the key word in that is assume is ass isn’t it lol
11-28-2020, 04:22 PM
My 2017 TV does but the sound bar that controls sound and video doesn’t. The DVD player that was installed doesn’t either.
2017 Forest River Surveyor 251rks
2022 Chevy 3500HD High Country
11-29-2020, 08:50 AM
I think you are asking to use the old cables as a fish tool.
Most likely it wont' work, they will be attached inside the walls with tie wraps that are screwed in place to keep them from flapping vibrating and chaffing.
NM Wildcat told you the best solution. Figure out the best route and just route them where you need.
If you put them under the camper, along the frame is best, you can put a wire loom around it to protect it and use self tapping screws to hold it in place with those tie wraps I talked about that have a hole to screw them in place.
https://www.lowes.com/pd/Utilitech-3...-Ties/50005768
PS, if it is necessary to make holes in the flooring be certain to fill it up with foam when you ae done to keep critters out.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
11-29-2020, 06:37 PM
Sounds good. Thanks y’all.
11-29-2020, 07:33 PM
Just a note that HDMI cables do lose significant amounts of quality video as the runs get longer. If you are going on a long run of up to 25 ft. ...use a more expensive cable with additional shielding AND a thicker AWG gauge.
Runs of over 25 ft may expect to see progressively more loss with length regardless of quality.
________
Cam
2015 Georgetown 280DS
11-29-2020, 08:45 PM
I agree to a point. I don't know how significant the loss is. I am currently using a 50' one way HDMI cable and notice no difference in quality. And it wasn't even an expensive cable
