10-02-2021, 09:28 PM
#21
Do you get sway at 55 mph? Also what trailer tires and load range? Put maximum load range that will fit.
10-02-2021, 09:37 PM
#22
Load range E. Castle Rock ST 266. 75mph max. China made tires
10-02-2021, 09:39 PM
#23
No sway at 55mph
10-02-2021, 09:41 PM
#24
No sway at 55mph
10-02-2021, 10:15 PM
#25
Unable ro remove sway in TH
To me it sounds like there is just not enough weight in the front of the trailer. Especially with a nearly 2000lb toy in the back. That’s a lot of weight behind the axles. I would fill up the fresh water tank and stuff a bunch of stuff in the front of the trailer and go for some test runs. Also perhaps your trailer is a bit nose high on the hitch perhaps???
Past Tow vehicle but still own: 2017 Ford Expedition XLT EL factory tow package. Added towing mirrors, 10 ply tires on separate rims, sumo springs, larger rear sway bar.
Current tow vehicle: 2020 Ford F350 Lariat supercab
4x4. 7.3 gas. 4,400+lb payload capacity.
2021 Cherokee Greywolf 23MK
Equalizer 1,000lb WDH
10-03-2021, 07:57 AM
#26
Unrelated to your sway issue, but a lot of folks here would recommend replacing the castle rock tires ASAP.
Me included.
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
10-03-2021, 08:02 AM
#27
Pin pointing the problem is as simple as Google can make it. Fix your physical weight distribution, a WDH just relieves weight from the rear axle -- and the weight at the back of the trailer has already made the trailer tongue lighter than it should be for safe towing.
-- Chuck
10-03-2021, 09:24 AM
#28
Weekender
Sway
My 4 point Equaliser hitch worked perfectly. Then on one of our trips, we started getting sway. We found the problem to be the bolts on the hitch needed to be Torqued, after Torqueing everything went back to no sway. If all of the weight is proper torquing may help. I had to buy a digital torque wrench because one of the bolts was over 300 psi. Good luck
10-03-2021, 12:26 PM
#29
A little over 60mph. Trailer rides fine w/o the RZR so I know it's the problem.
At least you know exactly what the problem is. If you fill the freshwater tank will it get you back to the same tongue weight percentage with the RZR in back as you had when empty?
Before buying a $3000 hitch I'd call them and ask if it will stop swaying caused by too little tongue weight. To me that just seems to be an expensive band aid.
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
10-03-2021, 12:29 PM
#30
Unless you get the tongue weight corrected anything that you do will only be hiding the real problem....
2015 Flagstaff 26FKWS
Ram 1500
10-03-2021, 08:15 PM
#31
My fresh water tank is about 11 ft. in front of my axles and about 14 ft. from the hitch. Do you think that will help?
10-03-2021, 08:20 PM
#32
Definitely.
2015 F350 6.7
10-03-2021, 08:23 PM
#33
Exactly. I bought the make and model due to needing a 13' garage (RZR is.12'6"). This trying to tow this trailer has been a nightmare to the point I just want to park it. Maybe it's just not designed for this much weight. Next new suspension, new tires and still have a 30k piece of junk.
10-03-2021, 08:24 PM
#34
I would try it for sure. I always fill my tank because I like my tank full when I arrive and the trailer just feels like it more planted on the road. I would imagine with the 1900 lbs of weight in the back your water tank was located in front of the axles for a good reason to help offset that. I’d load up your toy, fill the tank and hit the road. Bring tools with so you can pull over and adjust the hitch if need be.
10-03-2021, 10:01 PM
#35
almost everyone says to shift weight up front
filling the fresh water tank will add 300+ pounds to the front which would be an easy and inexpensive test...
then either scale it to get real world numbers on the hitch or build that scale using a bathroom scale described above...
chances are the answer to your dilemma is as easy as doing those two things...
2014 Shamrock 183
10-04-2021, 06:44 AM
#36
Back your razor into the trailer, if the back end is the end with the engine. Ive had to do this on regular utility trailers to get my tongue weight up.
10-04-2021, 07:52 AM
#37
oops! Looks like you have tried that already!
10-07-2021, 06:31 PM
#38
why so much tire pressure on truck.? mine! puma 298fqu. toy hauler and i run door recomendations for tires . michelin xts ,perfect wear. buy a smaller ,lighter razor
10-07-2021, 06:41 PM
#39
Let’s go with the second most expensive way of fixing this.
Or let’s go with the most expensive way. Buy a 5 wheel toy hauler and a new truck.
Filling the fresh water tank which he says if forward of the axels might be all it needs.
I recommend that first.
2015 F350 6.7
10-07-2021, 07:12 PM
#40
Just maybe because on a 3/4 ton, THAT is the recommended maximum tire pressure!
