Is there a "reset" button on the end of the pump motor? If pump motor has a thermal circuit breaker inside it's either reset by a button or should automatically reset when housing cools down.
If no reset button, make sure motor is cool, power is available to pump wires, and if not running give the motor housing a good RAP with a screwdriver handle. Sometimes that jars the motor back into live.
First thing to determine is whether or not there is actually power to the pump's pressure switch and when pressure is down, the power goes to the motor.
One of the many reasons why a good Multi-Meter is so essential when one owns an RV.
