Old 06-21-2024, 03:17 PM   #1
BobA's Avatar
12V DC Water Pump Recommendation
I have a four-year-old Lippert Flow Max 12V RV Water Pump in our travel trailer. The pump still works great, but the mounting foot cracked in half sometime during our last outing. So now the pump shakes and vibrates when running.
And, of course, you can't buy a replacement mounting foot. How convenient for Lippert...... $$$$.
There are other manufacturers of low-capacity (~3 gpm) 12V water pumps. I would be interested in your recommendation(s).
The advantage of going with the same pump is there would be no new hose connections to run.
Thanks for your time.
Bob in Grand Rapids, MI
BobA is offline   Reply With Quote
Old 06-21-2024, 03:29 PM   #2
Super glue it or put a zip tie around it, the type that have a loop at the end for a securement screw.
2016 Sunseeker 3010 DS
If dogs don't go to heaven, when I die I want to go where they went.
Will Rogers
Sunseeker16 is offline   Reply With Quote
Old 06-22-2024, 04:52 AM   #3
I would try some JB Weld.
Mokurt is online now   Reply With Quote
Old 06-22-2024, 07:59 AM   #4
3 legs will work
buy some rubber matting to dampen vibration
Plastic glue that "melts" the plastic then sets hard.... is better than JB weld or super glue
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 06-22-2024, 08:47 AM   #5
Chuck_S's Avatar
You can pick up this pump at Home Depot this morning All these pumps have common fittings so it's not important to get one this color.
Or just run with 3 bolts and some rubber vibration dampers -- Home Depot again -- which I thought came with all these pumps.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 06-22-2024, 09:24 AM   #6
D W
D W's Avatar
I don't think JB Weld would bond to the plastic mounting foot.
2016 Salem 27RKSS
D W is online now   Reply With Quote
Old 06-22-2024, 09:32 AM   #7
Take the broken foot off so it doesn’t have anything to vibrate against and have a beer.
MGD1961 is offline   Reply With Quote
Old 06-22-2024, 03:11 PM   #8
Job weld
Jb weld makes an epoxy specific for plastics. It worked well on what I tried it on.
Syrup is offline   Reply With Quote
Old 06-22-2024, 03:31 PM   #9
I would use some 5 minute epoxy and repair the foot.
Some rubber under the feet is a good idea.
Shur-flow makes dependable pumps.
ppine is offline   Reply With Quote
Old 06-22-2024, 04:58 PM   #10
BobA's Avatar
Thanks to everyone who replied. I will attempt to use some type of adhesive to reattach the foot. I had bushings underneath the pump previously, so I was surprised that this happened. Bob in Grand Rapids MI
12v, pump, water, water pump
