Old 11-03-2014, 06:15 AM   #1
1st time winterizing
We have a 2013 Rockwood Roo and have paid someone to winterize it for the last 2 years. We want to do it ourselves this year but have a question. I know we have to by pass the water heater. There is an Anti-freeze inlet on the outside of the camper. Do we just hook the anti freeze jugs up to that and turn on the pump? Or is there a valve somewhere that also has to be shut off in order to use that inlet? Any help/tips would be appreciated!!
dec1952 is offline   Reply With Quote
Old 11-03-2014, 07:00 AM   #2
Jimandchris's Avatar
There is a valve you have to turn in order to have the pump suck from the antifreeze inlet instead of the fresh water. Valve should be fairly close to the pump.
Ours was hard to find at first.
2019 Coachmen Freedom Express 281RLDSLE
2018 2500 HD Silverado
Equal-i-zer Hitch E4
Jimandchris is offline   Reply With Quote
Old 11-03-2014, 07:20 AM   #3
You can also use an air compressor to blow out the lines. Remember to open the pressure relief valve on the hot water heater before removing anode.
Good luck,
Don
Don and Michele
3 Adult Children - 5 Grandchildren
Present campsite - future homesitehttps://i246.photobucket.com/albums/gg119/dmdrj5/lake/dividingcreekviewfromhouselocation.jpg?t=120311985  4
dmdrj5 is offline   Reply With Quote
Old 11-03-2014, 07:37 AM   #4
Witch Doctor's Avatar
I have a Rookwood but not the Roo, first time I had the same problem wouldn't suck in, found the FW valve nowhere close at all but follow the line from the pump, once I closed that it drank the juice. Also that is not in the book that came with the unit.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-03-2014, 08:35 AM   #5
Just a Few (DO THIS FIRST) things, turn OFF the 110V switch on your W/H,this is located out side on the W/H, turn the(3) W/H bypass valves for Winterize, turn OFF the water pump and open the H&C faucets, Now remove the A/Rod plug from your W/H,this will require a (1 1/16 6PT Socket) while it is draining ,now OPEN the Low water drains & the F/W tank drain! This is just some Tips to elevate Problems in the future! Youroo!!
Old 11-04-2014, 06:56 AM   #6
winterizing using anti freeze inlet
Is there just one valve that has to be closed (the one to the F/W tank)? Do I have to open another one some where else?
Old 11-04-2014, 08:22 AM   #7
Alleged curmudgeon
Vern's Avatar
dec1952 - My Windjammer has two valves, one from FW tank and one from the anti freeze inlet. I must close the former, open the latter, to pump the AF through the system using the water pump.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34); 2018 (39); 2019 (30); 2020 (13)]
Vern is offline   Reply With Quote
Old 11-04-2014, 08:50 AM   #8
Which roo do you have? I have only one valve to switch for antifreeze inlet on our 2014 23ss. You do want to be sure to have your valves in bypass for the water heater.
Old 11-04-2014, 05:03 PM   #9
all trailers are different. Depending on the valves. After you open your low point drains. You have three vales to turn on the Hot water tank for the by pass and on mine I just have to close the FW valve hook up the hose to the anti freeze line and open a faucet to start that starts the pump. I start with the kitchen sink on cold then the bath, shower and out door shower then head then I open the hot side in the same order then I'm done. Total 4 valves have to be turned only on mine. then I add pink to the pee traps and dump a little baby oil on the head seal. Drain the FW tank if you do not have tank heaters and are not plugged in I'm plugged in all winter. I leave my space heater at 65 degrees and open the cabinets door and tank heaters on if it drops below 32 for more the 2 days.. That's it for me. Your's could be different but not by that much. The space heater keeps mold from growing. I'm lucky mine is plugged into a dedicated 30 amp service I installed at home.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-04-2014, 05:42 PM   #10
KDHfan's Avatar
I suggest spending some time on YouTube... Just go there and search RV winterization. There's plenty to watch and one of them will probably match your camper. Really helps to know what the process looks like.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
winter, winterize
