Old 08-10-2020, 06:41 PM   #1
2902ws water system issues...
Ok, maiden voyage in our new 2902ws....all seemed ok when sanitizing and flushing the FWT and lines but I noticed on the 2nd camping day that the pump continued to run. The system was pressurized but lower than usual and you couldn’t hear the pump running in the trailer. Checked via the access door and noticed the filter housing ( with the new filter in it that I put in right before we left) was partially full and the pump was running with a quiet hum.
First order of business was to shut it off under fear of water leaking badly some where. Nope. All good every where. Pulled the filter in case it was bad, reinstalled the housing without the filter and tried again. Sometimes it would shut off fully while others it would keep the low hum. Seems to be completely random.
I can see air in the inlet pump strainer and in the clear housing when the pump is running which explained while we were getting air each time we used it. I figure I have a loose connection so that is my next investigation. We just let the pump pressurize the system until we couldn’t hear it (took a while longer than it should due to the air in the lines) and then turned the switch off. We turned it on when we needed to use that water. Very manageable. Note: even when turning on the pump the next morning it wouldn’t run....there wasn’t sufficient loss of pressure/leaking. I also checked the winterizing valve was in the correct orientation which I never changed but did cycle it when checking this issue.
Three questions:
1. Would air in the pump cause the continuous (low hum/vibration) pump operation?
2. Should we have opened the water miser at the shower when priming the system (we didn’t use the shower).
3. Does anyone know why there appear to be two lines that join up before the pump inlet line just before the valve for winterizing?
2019 RW 2902WS
2019 Ford F-150 CC 4x4 w Max TT
TheMcBees is offline   Reply With Quote
Old 08-10-2020, 06:52 PM   #2
Head Rambler
1. Yes. Air in the pump will cause it not to build enough pressure to shut off.
2. Probably, but it may not have made a difference. You can open it and try to purge the system again if you'd like.
3. That is an interesting configuration. I'm guessing, but one could be a low point drain for the system.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 08-10-2020, 06:58 PM   #3
Thanks. Good thought on the low point drain being one of the lines. Will try the to bleed through the miser before the next trip.
2019 RW 2902WS
Old 08-12-2020, 08:31 PM   #4
Turned out to be the strainer housing not being fully tight. I didn't notice it moving anyway when I checked the strainer. When I installed a hose to the winterization fitting it leaked instantly. Tightened it 1/4 turn more (by hand) and the leaked stopped. Switched over to the tank feed and all is good. Whew. Easy.
2019 RW 2902WS
water
