Old 09-22-2020, 06:49 AM   #1
360PDEK water problem
I just bought a 2015 Sandpiper 360PDEK.
I hooked up the water and i noticed that the carpet by my fridge and stove was getting wet. Went outside and its flooding all over underneath the rv as well. My floor is soaked. Does anyone have a plumbing diagram for this?
What is the easiest way to fix this?
davey731 is offline   Reply With Quote
Old 09-22-2020, 07:39 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. there are no plumbing schematics for these rigs. Make sure when you hookup to city water you have a pressure reducer installed it may be that a connection is leaking because of to much pressure. I would pull the corpolast (under belling covering) and dry things out while looking for the problem. you may need to pull some panels inside to trace the lines good luck.
Retired Navy
2016 Flagstaff 26 FKWS
water
