Originally Posted by pdqparalegal1
Not familiar with any of the rv's Bidets so I have to ask "where does the hot and cold water mix and how is it adjusted?"
The "wand" I have seen in rv's is just cold and used to rinse down the bowl.
I had my concerns about water temp as well but they proved to be unfounded. You do not need hot water. The water in the line is room temp, and fresh water tank water is only slightly cooler, or warmer depending on outside temp. Even city water isnt a concern because you use the water in the RV before "new" water ever makes it there. Its a non issue really.
