Just bought a 2014 Freedom Express 233RBS. Water pump leaking from housing. It is located behind electrical panel and beside hot water tank. You can't get more than your hand through the small access hole. Anyone know how to get to the pump to remove and replace it?
When I installed the winterizing valve I pulled the converter, electrical panel, out. There was plenty of slack wiring to set it aside without disconnecting any wires.
Thanks for the comment. Wasn't sure about the panel removal, but now at least I know someone else did it. My as well add on the winterize valve at the same time. Thanks.
