Old 06-12-2024, 05:27 PM   #1
Accessing Water Pump
I have a 2022 Alpha Wolf TT and running into issue with the water pump. I need to replace the pump, take apart and repair or put in a check valve. The water pump is filling up the fresh water tank when connected to city water.
Questions is how to I get to the water pump? Does the panel on the right come off? Even if it did, that is a pretty tight fit. Am I missing something obvious?
Thanks in advance!
JerryDen is offline   Reply With Quote
Old 06-13-2024, 05:36 AM   #2
Have you checked the valve(s) for switching water source?
Mokurt is online now   Reply With Quote
Old 06-13-2024, 07:40 AM   #3
fipntdot's Avatar
I see this is your first post. Welcome. There are a lot of Alpha Wolf trailers. Please specify the model number and someone with that model may be able to tell you. I had a few odd things to find early on and when I posted the model I had several helpful answers. I would suggest looking in cabinets or other areas for removable panels. That looks like a tight spot.
Have you tried running the pump while not using city water? Sometimes that resets the check valve.
22 Freedom Express 257BHS
19 F-150 3.5 Max-Tow
fipntdot is offline   Reply With Quote
Old 06-13-2024, 03:33 PM   #4
Thanks for the info.
Yes, 1st post! Alpha Wolf 33BH-L.
I tried swapping between the city water and pump about 6x to see if that reset. Seems like the easiest fix is going to be to put a check valve right before the water pump. This would prevent the water from going to the pump on city water and not impact water coming from fresh water tank.
I am going to look for a check valve and 1/2" shark bite attachments to install. This would be closer to the open area, think I can squeeze in.
Old 06-13-2024, 03:38 PM   #5
fipntdot's Avatar
There should be a check valve already. It must be faulty.
pump, water, water pump
