Old 08-28-2020, 10:31 AM   #1
Air in water lines when running on tank
Hey all,
Iím on my first dry camp with no hookups. We filled the holding tank and ran the pump to pressurize the system.
Seems the pump in pulling air into the lines. All faucets are bubbling and spitting even after purging for several minutes.
I can hear gurgling at the pump.
I pulled the access panel an donít see anything off with the pump. No leaks.
I confirmed I have water in the tank at the drain (pickup is 3 inches from the drain) and the winterization valve seems to be in the correct position for use.
Any suggestions or thoughts as to where Iím drawing the air?
This has never happened on city water.
Oh, the camper is a HW296.
Bryan
bryankloos is offline   Reply With Quote
Old 08-28-2020, 10:33 AM   #2
nomad297's Avatar
It sounds like the diverter/valve located right at your pump is in the antifreeze suction position. Take a look to find the valve and switch it over.
Bruce
nomad297 is online now   Reply With Quote
Old 08-28-2020, 10:41 AM   #3
Originally Posted by bryankloos View Post
Hey all,
Bryan
If there is a strainer installed before the pump like many have make sure the 0-ring is installed and it's tight . check the pump connections also sometimes they are only hand tight
MR.M is offline   Reply With Quote
Old 08-28-2020, 10:50 AM   #4
Hey all,
Bryan
Was the water heater empty prior to starting the pump? If so, it can take a while to purge that 6 gallons of air.
2019S Mod Thread
https://www.forestriverforums.com/fo...ad-184896.html
2020 Rockwood Mini Lite 2109S
2017 GMC 2500HD Denali 6.6L Duramax
01tundra is online now   Reply With Quote
Old 08-28-2020, 11:08 AM   #5
Water heater had water from two weekends ago. We didn’t drain. It’s also the cold side. I’ll check the divergent valve again. I do have a strainer and I see some washers on the ground near it. I’ll check that as well.
Just need to find the best way to access the pump with some working room.
Old 08-28-2020, 11:21 AM   #6
The pump's suction strainer is usually a clear bowl/housing that screws directly to the pump. Not sure why there would be washers on the ground?
Days Camped: '18=51 '19=58 '20=110 '21=15
Old 08-28-2020, 12:33 PM   #7
You are sucking air from some place. I would start at the pump and give all the fittings a turn. I bet you find a loose one.
shadows4 is offline   Reply With Quote
Old 08-28-2020, 01:53 PM   #8
If all else fails...
We had this happen the first time we took out our new trailer and searched everywhere for a loose gasket or fitting, anything - it turned out someone at the dealer left the shower miser system turned on.
It's a simple check that might save you some time!!
Good luck!
CampJen is offline   Reply With Quote
Old 08-28-2020, 09:40 PM   #9
Had a similar issue with our new TT. It turned out to be the strainer housing to the pump. 1/4 turn more and the issue was resolved. At least in the driveway. Next trip is soon. That will be the true verification.
2019 RW 2902WS
2019 Ford F-150 CC 4x4 w Max TT
TheMcBees is offline   Reply With Quote
Old 08-29-2020, 08:44 AM   #10
Water heater had water from two weekends ago. We didnít drain. Itís also the cold side. Iíll check the divergent valve again. I do have a strainer and I see some washers on the ground near it. Iíll check that as well.
If you have one, there's been several cases of the showermiser fittings leaking behind the wall and drawing in air.
2019S Mod Thread
Old 09-03-2020, 04:00 PM   #11
Fixed the leak today. It was the elbow fitting attaching the hose to the strainer. Seems it was over tightened at some point and would simply spin when the collar was fully seated on the threads. I replaced the 90 degree elbow and the strainer as I didn't like the current strainer. After everything was tightened down order was restored.
Thanks for the help!
Bryan
Old 09-03-2020, 04:14 PM   #12
bikendan's Avatar
Thanks for coming back and letting us know what the problem was. Glad you were successful.
Old 09-03-2020, 05:38 PM   #13
Great news. It always feels good to get an issue resolved!
Old 09-04-2020, 05:40 AM   #14
nomad297's Avatar
X2
Bruce
tank, water
