Originally Posted by emeth
We have found that dumping every other dish-pan, (or some), of soapy water down the Black tank, (instead of all down the Gray tank), serves to keep solids moving.
We also do not put paper in the Black tank, (keeps build-up and sensors clear).
Also, we add inexpensive fabric softener after each dump, (keeps everything slippery and saves a ton of money for 'Digesters).
It is also important to use toilet seal lube periodically for both the Toilet seal and, (as it flows through the tank), the dump seals as well.
None of these methods, (as far as I know), would be harmful to the Park's Waste Systems; they may very well help).
I'm hoping you meant to say water softener. Fabric softener is something entirely different and won't keep anything "slippery."
2011 Traverse LT, 3.6L, FWD
