Old 11-10-2020, 11:08 AM   #1
DunnDeal's Avatar
Aluminum or magnesium anode rod?
I need to change out my anode rod and noticed that there is an aluminum and magnesium anode rod. Which is better to use. Some writers say that the aluminum will last longer.
Charlie
2020 Forest River Rockwood Mini Lite LT2104S
2016 Ford F-150 Crew Cab XLT Truck
WDH: Husky Centerline
DunnDeal is offline   Reply With Quote
Old 11-10-2020, 11:28 AM   #2
SeaDog's Avatar
I have never looked at which will last longer but rather which I feel do the best protection. I go with the more expensive magnesium which seems to sacrifice itself faster.
Retired Navy
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 11-10-2020, 11:31 AM   #3
Maybe it's just me....but I don't want my anode rod to last too long. When it gets "eatin' up", it means my tank isn't! And since I have to remove mine every year for winterizing, it's cheap enough to replace annually ---- at least cheaper than replacing the tank.
2019 Cedar Creek Silverback 37MBH
TV: 2017 Ford F350 CC DRW King Ranch
jd4010 is offline   Reply With Quote
Old 11-10-2020, 11:45 AM   #4
Jim34RL's Avatar
I have had both and they seem to last about a year to maybe two years at the most but that is all. Cheap insurance to buy a new rod every camping season for me, which I do now.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 11-10-2020, 11:46 AM   #5
wmtire's Avatar
Over in the FAQ subsection under water heaters we keep a sticky there of 5 video guides provided by suburban. There is one there that explains the anode rods and also the difference between the use of the magnesium or aluminum type.
See if this link takes you there. I have a problem with doing this on an app sometimes
https://www.forestriverforums.com/fo...es-135977.html
2011 Flagstaff 831 RLBSS
I often say to myself, "I can't believe that cloning machine worked."
Old 11-10-2020, 11:51 AM   #6
Here's what a plumbing company says (as do dozens of others when you do a net search)
Magnesium anode rods are expected to work better in a home with soft water.
Aluminum anodes are appropriate for homes with hard water and a high PH.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 11-10-2020, 12:39 PM   #7
DunnDeal's Avatar
Thank you wmtire for the links and TitanMike for your comments (along with the other posters)
Charlie
Old 11-10-2020, 02:43 PM   #8
bikendan's Avatar
Depends on your water. The one in our previous trailer lasted 7 years before needing replacement.
Old 11-10-2020, 02:51 PM   #9
jeff64's Avatar
Flip a coin
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 11-10-2020, 09:26 PM   #10
Chris Pastuzyn's Avatar
As already mentioned, Cheap insurance, try one,then the next time try the other,See what works best for you ?
Chris Pastuzyn is offline   Reply With Quote
Old 11-10-2020, 10:03 PM   #11
Just for grins and giggles, there is a third type of anode for another specific purpose other than tank electrolysis. ZINC or Aluminum/Zinc. This rod is used to combat the rotten egg smell some water sources are prone go create.
2004 Nissan Titan
Old 11-11-2020, 07:38 AM   #12
PhD, Common Sense
Originally Posted by jeff64 View Post
Flip a coin
Copper or silver?
eye95 is offline   Reply With Quote
Old 11-11-2020, 08:03 AM   #13
jeff64's Avatar
Originally Posted by eye95 View Post
Copper or silver?
It would have to be an old one to find either metal.
You find zinc anodes on marine engines
14K Equalizer
Old 11-11-2020, 08:40 AM   #14
KyDan's Avatar
When I had a suburban WH it came with a zink anode and after a few years it was about 50% gone. I burned out my heater rod and while changing it I also replaced the anode with aluminum. After a couple years it was hardly pitted at all.
I took that to mean the magnesium was better- in my case anyway.
I meant it came with magnesium anode!
Question: who here has had their water heater tank rust out and leak??
Anyone??
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-41
Old 11-11-2020, 09:30 AM   #15
Chuck_S's Avatar
Nothing wrong with the anode in the photo. This ain't a beauty contest. Years of life left.
-- Chuck
Chuck_S is online now   Reply With Quote
Old 11-11-2020, 10:42 AM   #16
Brake is on left
The Evil Twin's Avatar
After doing a little research and watching the video, seems for most applications the mag probe is the way to go for me. If it gets eaten more quickly it would stand to reason it protects better. As it sacrifices itself more easily. Our water isn't hard either. Maybe for well water it would be different.
The Evil Twin is offline   Reply With Quote
Old 11-11-2020, 10:44 AM   #17
And even then that will vary from region to region, depending on the mineral content of the well water.
2004 Nissan Titan
Old 11-11-2020, 10:46 AM   #18
DunnDeal's Avatar
Thank you Chuck_S for your comment.....At what point is the anode rod no longer good if this one has more life?
Charlie
Old 11-11-2020, 11:01 AM   #19
When all you see is the center wire.
Problem is, when that happens you don't really know how long it's been like that and how long the tank has been unprotected.
The rods are not all that expensive. Tanks are.
Replace and don't try to squeeze the last little bit o use out of it.
2004 Nissan Titan
Old 11-11-2020, 11:22 AM   #20
Tapex's Avatar
Image description of erosion Click image for larger version
2016 Coachmen Apex 250RLS Ultra Light
2019 Ram Big Horn Sport Longhorn
Tapex is offline   Reply With Quote
aluminum, anode
