Old 09-25-2014, 04:47 PM   #1
Anode query
Hi all
I have heard from many sources that the socket size needed to remove the Anode rod on a Suburban water heater is 1 1/16. I tried one in that size, but it doesn't seem to fit properly. (seems a little to small). Not sure what the problem is, could anyone offer any advice?
Many thanks!
thumperpaul is offline   Reply With Quote
Old 09-25-2014, 05:18 PM   #2
a bigger socket??
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 09-25-2014, 05:24 PM   #3
wmtire's Avatar
A one and 1/16th is what I've always used. I wonder what the problem could be, as if the socket could be sized/marked incorrect, or something else.
Now, the Suburban electric element is one and 1/2 (but it would be a big difference). Is there any chance you are confusing the two?
2011 Flagstaff 831 RLBSS
I'm trying to keep up with the Joneses, but every time I catch up, they refinance.
Old 09-26-2014, 04:56 PM   #4
Nope...it's the big plug on the bottom. I've watched and read quite a few tutorials on the removal, and I'm quite sure. The last time I had my Wildwood at my father in-laws, I noticed that he had a 1 1/16 socket, so I tried to fit it. It just won't quite go over the anode fitting. I have the trailer at the dealership right now for some warranty work, I think I'll ask the guy at the service department when I pick it up.
Thanks for your reply!
Old 09-26-2014, 05:11 PM   #5
B47
Same here - there's a big enough difference between the two sizes to cause his problem.
Old 09-26-2014, 05:11 PM   #6
Ford Idaho's Avatar
Is the socket a 6 point or a 12 point?
A 6 may work better.
Old 09-26-2014, 05:24 PM   #7
Inspect the anode hex itself for burrs, etc.
Old 09-26-2014, 05:27 PM   #8
Mine is a 1 1/16, 12 point. Works on my currently installed rod and I just checked my spare. Works there as well.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 09-26-2014, 05:46 PM   #9
Canadiancrew's Avatar
I went to look at the socket I used and it happened to be metric. So it turns out I had used a 27MM 6 point which is approx 1 1/16". My trailer is out in storage and not at the house or I would go see if a 1 1/16 works or not.
Canadiancrew is offline   Reply With Quote
Old 09-26-2014, 05:48 PM   #10
The 27 mm is about 0.010" too small.
Old 09-26-2014, 06:05 PM   #11
Ford Idaho's Avatar
OOPS!
I rather dislike it when that happens.....
Old 09-26-2014, 06:12 PM   #12
I think the socket I tried was a 6 point, if I recall. Definitely was marked 1 1/16 though.
Old 09-26-2014, 06:17 PM   #13
Mikegjax's Avatar
Pulled mine yesterday, 1 1/16th.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 09-27-2014, 07:25 AM   #14
wmtire's Avatar
Any chance the water was still hot in the heater, before you attempted this? I'm just spitballing here, and thinking maybe if the heater was hot, the anode rod head metal may be expanded a hair.......and if you put a cold Canadian socket on it, that was the minute difference.
Old 09-27-2014, 07:36 AM   #15
I think he said he used a 27mm socket which is 0.010 too small and not a 1-1/16" socket.
Old 09-27-2014, 07:39 AM   #16
wmtire's Avatar
That wasn't the OP who made that statement. The OP (thumperpaul) confirmed he tried a 1 and 1/16th a few posts up in post #12.
If I am understanding correct, the member (Canadiancrew) in post #9 who did use the 27 mm, was successful in it.
Old 09-27-2014, 05:25 PM   #17
Hutch333id's Avatar
Just used a 27mm socket to remove mine with no problem whatsoever. The water in the tank was hot as well. Once drained wrapped the threads in PTFE tape and loosely fitted it back in, ready for next season.
Richard & Diane
2014 Cedar Creek 38FL
With a F350 dually
2014 41 nights and 4620km.......and we're done
Richard & Diane
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
Hutch333id is offline   Reply With Quote
Old 09-27-2014, 05:35 PM   #18
mcnabbwr's Avatar
I just checked mine and it's 1 1/16. Tried both six and twelve point sockets. As stated before maybe a burr or something.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 09-27-2014, 06:48 PM   #19
Nope, she was stone cold...
anode
