Old 08-28-2021, 10:37 PM   #1
Another dometic toilet issue
We have a 2019 fsx and just this year we have noticed that about 5 minutes after we flush, urine is seeping back into the bowl. We end up flushing 5 or 6 times to get it to stop. Now, even when the holding tank is freshly emptied, the bathroom reeks of urine. I see the other threads about the smell issue, but what about the urine seepi g back into the bowl from under the seal? Anyone else notice this?
Speck007 is offline   Reply With Quote
Old 08-29-2021, 05:26 AM   #2
Urine can’t seep back into the bowl unless that is what you’re filling your fresh water tank with. More likely you have a contaminated fresh water supply issue. This can happen if untreated fresh water is allowed to stay in the system too long. Best bet is to flush it all out then treat it with a bleach/water solution flushing it through the whole system. You may have to do this a few times depending on how much the system has been contaminated. Once cleaned be sure to keep it clean by either draining the system after use and/or adding fresh water treatment to it.
2021 Rockwood Mini Lite 2205S
2011 Ford F-250 Super Duty 6.7L Diesel
WanderMore is offline   Reply With Quote
dometic
