08-29-2013, 09:25 AM
#21
Originally Posted by Bryan2503S
When I do a web search on Oxygenics I see many different models. What model are people around here getting?
Post #(16) they come in (3) flavors,Your pick! Youroo!!
08-29-2013, 10:03 AM
#22
Yes, from what I saw earlier, their web page doesn't even show the models that we get from Camping World that has the shutoff on it. Not good. I almost bought the one on Amazon and then noticed that it doesn't have the same function, even though both are "Body Spa", so beware.
08-29-2013, 10:20 AM
#23
Always Learning
I have an Oxygenics without a shut off. For that, I use this right above my water handles:
But, I surely didn't spend $15 which is what Amazon is showing for it. (Looking at my Amazon order history, I spent $9.64 on it.)
08-29-2013, 10:31 AM
#24
This is the proper way the shower assy should be oriented. The shutoff valve was purchased at (ACE hardware). The holder on the wall is a stock F/R holder,we travel many 1000 of miles without it (Falling Out) of this holder. You can use the stock white flex hose or the SS one,no mods needed. Youroo!!
08-29-2013, 10:34 AM
#25
I looked at two different models at the dealership parts store. One did NOT have the shutoff, but I had to look closely to determine that I needed the other one. Also, the existing shower head holder would not work for me because it would allow the oxygenics head to touch the edge of the skylight. I could imagine the road vibrations causing the head to crack the skylight.
So installed the provided new holder right where the old one was, and the angle of it lets the shower head clear the skylight by a couple of inches. This holder is also adjustable via a ball socket.
And the pressure is great. On my first outing with it, I had 60 psi provided by the campground system and thought it was going to blow me out of the shower. I think it's going to be great for campgrounds with lower pressure.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
08-29-2013, 10:43 AM
#26
When you buy, order one for your Home also! Youroo!!
08-29-2013, 10:54 AM
#27
You can tighten the ball by tightening the collar by it. Mine wanted to droop and would bow down and fall out going down the road until I tightened mine by hand. Love the pressure I get with not a lot of water pressure coming in the RV.
Randy & Kathy & Auggie the Doggie
2012 F350 CCab
2011 Cardinal 3425 RT
08-29-2013, 11:42 AM
#28
Wanna Be Camper
Originally Posted by vwyatt
all this talk about Oxygenics shower heads makes me want one. Anyone able to tell me where i can pick one up in Canada? Thanks
https://www.oxygenics.ca/
John & Deb
2011 Flagstaff V-Lite 30WRLS
08-29-2013, 11:47 AM
#30
Originally Posted by MMattox
X2 WindJammer!
It should also be noted that despite the box saying that there Is a shut off valve on the new ones, it does not completely shut off the water, it still pee's a little bit when shut off. I actually thought that it was a leaky valve, but when I took it back to Camping World they told me that it does not completely shut off, why I have no idea. To me a on/off valve means just that. Other than that it works as described by others here and worth the investment.
The shut-off valve always pees a little to prevent scalding when you turn it back on. It does this by design. Since the cold supply always has slightly less restriction than the hot, it will dominate.
Bob
Bob & Doris
Roanoke, VA
2009 Toyota Tundra CrewMax 4x4 - 5.7L - 6 Speed Auto - 4.30:1
2013 Rockwood HW296
08-29-2013, 12:03 PM
#31
Phat Phrog Stunt Crew
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
08-29-2013, 12:05 PM
#32
Always Learning
Originally Posted by bob213
That's pretty neat. I ended up recently installing a 2nd shower head holder so that I wouldn't have to stoop down to wash my lovely mane.
I call them "his" and "hers" shower head holders.
09-01-2013, 08:47 AM
#33
The real problem with the factory shower is that the hole on top of the faucets where the hose connects is very small diameter to save water.I was thinking of drilling the hole larger
09-01-2013, 03:53 PM
#34
Jack, you are right. I drilled mine a little bit larger and it made a huge difference.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
09-01-2013, 03:56 PM
#35
Stop it right now or you are going to cost me money!!
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
09-01-2013, 07:25 PM
#36
That is exactly what I was thinking about doing. Did you use the same shower head model as the one in your RV? I wasn't sure it would do well with the increased household water pressure, might take the skin right off me
Thanks.
2021 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
09-23-2013, 11:03 PM
#37
Camping world sold me the chrome one for the sale price of the white.
09-24-2013, 10:22 AM
#38
aka Windjammer2012
Thanks.
You won't regret installing one in your home. You will find that you will only need to barely turn the water on the get a refreshing shower stream and therefore saving money on your water bill.
Wayne & Vonnie Layla (American Eskimo dog)
2012 Windjammer 3008W
2004 GMC 2500 HD CC Longbed
09-24-2013, 10:42 AM
#39
Bob
Right. I've never had a camper that didn't do this.
03-07-2015, 09:49 AM
#40
Do I need to purchase a Rv model one? I have a bed bath beyond gift card & they sell them. The head is much larger than pics show here
