Old 02-20-2024, 01:56 PM   #1
Another pex question
1300 miles from home, the plastic Tee coming off of the water heater cracked, and my Pex fittings, clamps, and crimping tool are all back home in the big camper. I know, I know, rookie mistake. Went to the only "RV parts store" around and they have nothing. SO, will a Sharkbite Tee work? I have never used Sharkbite fittings so I have no idea. Are they easily removable?
If not, any suggestions for a quick fix?
TIA...
2018 Rockwood Signature Ultra Lite 8311WS
2014 Coachmen Apex 215RBK
2018 GMC Sierra 2500HD SLT Duramax
Chazman is offline   Reply With Quote
Old 02-20-2024, 02:44 PM   #2
llr
you should be able to go to any hardware / home center for PEX.
I never used sharkbite but most people seem to really like them
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
llr is offline   Reply With Quote
Old 02-20-2024, 03:08 PM   #3
RV There Yet?
IsleDog's Avatar
sharkbite in a pinch. it should be replaced properly as soon as possible. most hardware stores you can rent tools like a pex crimper and get some fittings and be done in an afternoon while at your destination.
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
IsleDog is offline   Reply With Quote
Old 02-20-2024, 03:15 PM   #4
Shark bite will get you home just fine. Or if you are near the ocean go to a marina store and get Whale brand fittings. Like shark bite but are easily removed
I’ve been slowly replacing the plastic PEX fittings with brass in my rig as needed or if I’m staring at it with nothing better to do.
MGD1961 is offline   Reply With Quote
Old 02-20-2024, 03:59 PM   #5
NMWildcat's Avatar
And why do you think SharkBite should be replaced at all?
SharkBite fittings are rated for behind the wall usage and approved by plumbing code standards agencies.
I have replaced 90% of my RVs crappy banded connections over the years with SharkBite and have not had one leak or failure. Have used them in several barns and storage sheds.
They are a permanent solution.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
Old 02-20-2024, 04:08 PM   #6
NMWildcat's Avatar
TIA...
Yes, they are easily removable. But why remove them?
Pay a few bucks for the pex cutter and reaming tool to ensure you have a good connection. Just follow the simple instructions.
Old 02-20-2024, 07:01 PM   #7
Thanks to all for your replies.
Scott, the reason I asked about removing the Sharkbite is, the Pex tubing is not completely straight and smooth due to the previous Pex clamps holding it on the Tee. I thought if the Sharkbite needed to be installed on "virgin' tubing and wouldn't seal correctly I might have to remove it. Unfortunately, there is no "slack" or extra tubing so cutting any of the lines back is not an option.
Thanks again
Old 02-20-2024, 07:14 PM   #8
I'm with Scott, no reason to remove any Sharkbite fitting.
They will last longer than the plastic junk from the factory.
And most Sharkbite fittings are bigger so if you cut the PEX right at the very end of the plastic tee, you "should" have just enough pipe to make a good connection.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 02-20-2024, 07:24 PM   #9
More excellent info! Thanks for your reply.
Old 02-20-2024, 09:43 PM   #10
NMWildcat's Avatar
Thanks again
In replacing my banded fittings with SharkBite I had the same problem for some of the connections. i cut back the pex and used a coupling to install a new section of pex to reach.
Old 02-20-2024, 10:44 PM   #11
TIA...
I replaced all of the PEX plastic fittings with Sharkbite fittings. Got them at the local Lowe's store. All problems are resolved for now and in the future. Those cheap clamp-on PEX fittings are mostly junk, but they are cheap! Why does one think the RV is full of them?
RV parts stores usually have nothing suitable.
Bob
Name:	Sharkbite to FIP.jpg
ID:	297149   Click image for larger version
ID:	297150   Click image for larger version
Bob K4TAX is offline   Reply With Quote
Old 02-20-2024, 11:00 PM   #12
Bob
Agreed, on all points. I was telling my neighbor about it today and he asked if the Tee froze and broke. it wasn't cold enough for it to freeze here last night, but it got me thinking... being on the hot water side I'm sure after 10 years of hot and cold it got brittle, which probably contributed to the crack, but when I get home I will be replacing all of the plastic junk on all the water lines.
Thanks for your input Bob.
Old 02-20-2024, 11:01 PM   #13
X3
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
flyflotrtim is offline   Reply With Quote
Old 02-21-2024, 06:48 AM   #14
I think it should be mentioned that “shark bite “ has become an eponym for any fitting of that type. I’m with you if you are using the original brand made with a metal body but beware there are cheap brands too. The cheapest of them rely on water pressure to keep them sealed by compression of the o ring. Then when you disconnect from water and the pressure goes away they will drip until the pice is empty or pressure is restored.
Just saying.
Old 02-21-2024, 09:03 AM   #15
Old guy having fun
Believer45's Avatar
Just saying.
Good information, thanks MGD1961
2013 Forest River Windjammer 3008W
2011 Ram 2500 crew cab short bed diesel 6 speed auto 3.73 gears RWD
Believer45 is offline   Reply With Quote
Old 02-21-2024, 02:30 PM   #16
I have made some Pex repairs with simple hose clamps like the good ones used on radiator hoses. The ones with slots. No need to buy a bunch of crimping tools. No need to miss your tools back home. Sharkbite clamps are for homeowners on a budget.
ppine is offline   Reply With Quote
Old 02-22-2024, 09:15 AM   #17
Seems to me most people would prefer to use proper tools and parts for the job. I’ve MacGyvered lots of stuff too but I don’t think that’s the point here.
Old 02-22-2024, 09:30 AM   #18
Agreed and advising folks to use the improper clamps for PEX is an invitation for failure and not the advice one should expect on this (or any other) R/V forum.
As was mentioned earlier in this thread, SharkBite fittings are plumbing code approved, used by contractors everywhere and saying they are only for budget minded homeowner repairs is silly. BTW... have you purchased any SharkBite fittings? They are really not "budget friendly" but they work well and need no special tools/clamps.
Old 02-22-2024, 09:40 AM   #19
I just installed these day before yesterday after replacing the kitchen faucet because a cheap plastic braided hose blew off th bottom of the faucet and flooded the kitchen island. I have no intentions of ever replacing the fittings with anything else.
Old 02-22-2024, 09:48 AM   #20
grege's Avatar
....... Are they easily removable?
TIA...
Yes. You just need one of these removal tools.
'18 Ford F250 Lariat Super Crew
'22 Rockwood 2608BS
Previous '17 Grand Design Imagine 2800BH, '13 Rockwood Roo 21SS
grege is offline   Reply With Quote
question
