Things to do:
1. With the pump off open the faucets everywhere. Mt TT has three.
2. Change the valve setting on the water heater to bypass the water heater.
3. Drain the water heater and flush the sand out of it.
4. If you have a air flusher (tire connector to a male hose connection) set your air compressor on about 40# pressure and purge all of the lines with air (open the valves one at a time until it is burping air out).
5. Find the low point drains and drain them of water. Put the caps/valves back on. At this point most of the water should be out of the system. Don't forget the inside and outdoor shower and toilet in this process.
6. Near the water pump should be a valve that switches between the fresh water tank and the antifreeze inlet. Move to the antifreeze inlet setting.
7. Put your jug of antifreeze on a box. Buy/make a hose with a male hose fitting on one end and a plastic hose on the other to go inside the antifreeze jug.
8. Close all faucets/shower valves. Turn on the water pump and proceed valve to valve until the pink stuff comes out.
9. Pour some antifreeze down each drain.
There are other threads and videos on this website. Here is one of them:
http://www.forestriverforums.com/for...ion-69757.html
