Apex Nano- low point drain PEX is cracked
Hi all!
We have a 2016 Apex Nano 193bhs. Took it out for the first trip of the year last weekend and noticed that the low point drain was cracked and leaking just above the plug.
Is there a diagram anywhere that shows where the water lines run? I want to cut the pex above the crack and put a Shark Bite valve on, but don’t know if I have enough play on the outside. I may have to add a new piece of PEX to have enough length.
will I be able to get to the low-point lines in the access panel by the bathtub?
I hope that makes sense. Thanks I’m advance!
