Old 02-01-2023, 10:32 AM   #1
Arthritis hands and sewer hose connections
I own a 2022 Solera and I am having a lot of trouble coupling and uncoupling the sewer hose to the outlet inside the sewer connection cabinet. I can usually get the black cover off the outlet but often have trouble getting the hose connection secure before extending the hose to the dump hole. After dumping, I regularly cannot get the hose connection off in order to put the black cover back on the outlet. (There are always kind folks near me who can help.)
My arthritis is a real problem and the outlet is pretty far back in the cabinet. In addition the pulls for black and grey water opening are close to the outlet so there is not a lot of room to maneuver. Does anyone else have this problem? I have been thinking about leaving the sewer hose attached (making sure it is clean) and just threading it through the floor hole at the campground. Is this in any way a good idea? I have one of those orange tools (looks sorta like a jar opener) that allegedly helps remove the sewer hose but I can't make it work. What am I missing?
Sandy Roth is offline   Reply With Quote
Old 02-01-2023, 11:13 AM   #2
Here's a video about them. They shouldn't be that difficult to operate.
Iwritecode is offline   Reply With Quote
Old 02-01-2023, 11:16 AM   #3
Shoulda' retired earlier
n-e-d's Avatar
I have the same problem with arthritis. I use plumbers grease to lube the "O" rings,just a little dab will do you.
Mary and Me 😷😷 Stay Safe
2015 2650s "Finally" SOLD
2015 Jeep Cherokee Toady
2023 Geo Pro FD19 "Almost there"
2022 Race Car Red HR Long Ford Transit 250 "The Irish Rover"
'Twas a wonderful craft...And they called her The Irish Rover
n-e-d is offline   Reply With Quote
Old 02-01-2023, 11:27 AM   #4
This works great when the outlet is either outside the rig or with no impediments on either side. In my RV, the wrench cannot grip the fitting because the black and grey water pulls block the way. I really appreciate your help.
Old 02-01-2023, 11:40 AM   #5
llr
Might try a rubber strap wrench, I used them on a water filter canister before that was to close to get my hands around
TT 2021 Grand Design 2800BH
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
prior TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 02-01-2023, 11:44 AM   #6
When ever my caps start getting harder top remove I just spray the exterior (plastic surface) of the valve area with a spray lube. Thats seems to work well. I never notice the O ring. Might have to give that a little grease as well.
Jim M.
2020 Flagstaff Super Lite 26RBWS
Former: 2017 Rockwood MiniLite 2104S
2015 Silverado 2500HD 6.0L Gas
jimmarako is offline   Reply With Quote
Old 02-01-2023, 11:49 AM   #7
I am going to try everything n-e-d, llr and jimmarako have suggested. I think that may solve my simple but important to me problem. THIS SIGHT ROCKS!!!!!
Old 02-01-2023, 11:52 AM   #8
I'm a firm believer in the old adage: is it suppose to move? yes -> use WD-40. no -> use duct tape.
Old 02-01-2023, 12:20 PM   #9
WD-40 wouldn't be good for this application but plumbers grease or silicone lube (often called food grade silicone) will let those stubborn caps and hoses twist easily.
Days Camped: '18=48 '19=58 '20=110 '21=116 '22=112 '23=83
Old 02-01-2023, 12:43 PM   #10
Maybe you could leave something like this on the outlet to make the connection easier to reach? You could leave the cap on the end when you're not dumping (for "safety").
RockLobster is offline   Reply With Quote
Old 02-01-2023, 12:48 PM   #11
Perfect!!!
Yes!! This is exactly what I think I need. Ordering it now. Thank you SOOOO much.
Old 02-01-2023, 12:48 PM   #12
Ah... I see what you mean now. Found this from a YT video.
I wonder if putting some sort of clear extension on there might help clear the handles? Then you could just put the hose/black cap on that?
Something like this:
Old 02-01-2023, 12:51 PM   #13
You're welcome. I hope it works for you.
Old 02-01-2023, 01:02 PM   #14
I was wondering if a regular 90* would hook onto the existing connection and then line up with the hole out the bottom, thus no extra hose and then then orange tool should work just fine.
Marc in sunny California
2013 Crusader 260 RLD
2012 RAM 2500 Laramie CTD and 4:10
mmartin_tdc is offline   Reply With Quote
Old 02-01-2023, 01:08 PM   #15
Another great idea.
Attachment 283505
I think this is a great idea as well. Looks like I'm going to have a lot of options. Again, thanks to everyone.
Old 02-01-2023, 02:26 PM   #16
DogFather's Avatar
X2!
John, KA6CHX
2018 FR Berkshire 39A
DogFather is offline   Reply With Quote
Old 02-01-2023, 09:10 PM   #17
I use oil filter pliers.
leeshearer is offline   Reply With Quote
Old 02-02-2023, 07:16 AM   #18
My dear dad
Jim, that reminds me of something my father, a career Air Force officer, used to say: If it moves, salute it; if it doesn't move, paint it.
Old 02-02-2023, 07:36 AM   #19
I wish someone would design a hose that could fit the following type coupling Click image for larger version
2019 F 250 6.2
2022 Columbus 329 DVC
moose074 is offline   Reply With Quote
Old 02-02-2023, 08:32 AM   #20
Kanadian Kamper
kenandterry's Avatar
Originally Posted by moose074 View Post
I wish someone would design a hose that could fit the following type coupling Attachment 283552
Not sure if mine was factory equipped from Forest River, or someone else did it, but my sewer hose connects to my Sunseeker using the cam lock design. It’s so much simpler than the twist-lock design throughout the industry.
Only thing I can add……my Sunseeker was a previous rental unit from one of the largest rental companies in Canada.
Ken and Terry
Former Georgetown 330TS owner for 10 years with more mods than I can count
kenandterry is offline   Reply With Quote
