Old 04-11-2017, 01:31 PM   #1
Atwood heater not hot enough
Our new coach a 2018 Coachmen Mirada has an attwood hot water heater. When i turn the hot water on the water is warm but even with the hot fully open and cold not on at all its only luke warm. Brought it to the dealer and they said it was fine but i dont think something is right somewhere. Anyone have any ideas on how to get the water hotter?
manderson2228 is offline   Reply With Quote
Old 04-11-2017, 01:35 PM   #2
wmtire's Avatar
Check your crossover valve, if applicable. This thread may help. This is a very common thing.
http://www.forestriverforums.com/for...st-103381.html
2011 Flagstaff 831 RLBSS
I've reported my DNA missing just in case it's found somewhere bad.
Old 04-11-2017, 01:35 PM   #3
Prime Member
Check and make sure the water valves on your shower are completely off and not just switched off at the shower head. The same for the outside shower if you have one.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 04-11-2017, 01:47 PM   #4
I know these two are good to go. I'll have to check the bypass. We just bought the unit I am not even sure where to find the bypass.
Old 04-11-2017, 01:56 PM   #5
wmtire's Avatar
It's explained in the link in post #2, where you may can find the crossover valve.
Sometimes, it behind the water heater that you access from inside the RV somehow. You may have to go thru a cabinet, bed bottom, false panel, etc.
You could have a plumbing station that has the valves there
You could also have an access hole underneath the RV and behind the water heater that you unscrew to be able to reach up and turn the valves.
Please read the link in post #2 above.
Old 04-11-2017, 02:00 PM   #6
Flybob's Avatar
Locate the WH cover on the outside. Then go inside and there is a panel or drawer that will need to be removed from the inside in the same area where you located the WH outside.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-11-2017, 02:02 PM   #7
Yea this is what i mean. I understand how the bypass works especially after seeing post 2 with the diagram. I literally just dont know how to get to the bypass valve. Is it normally behind of water heater or on the side?
Old 04-11-2017, 02:12 PM   #8
Typically, behind.
Days Camped: '17=30 '18=51 '19=58 '20=83
Old 04-11-2017, 02:12 PM   #9
wmtire's Avatar
It's 'usually' behind the water heater, access of which is explained in the link.
You may have to access behind it from inside the RV....or could have an access hole underneath the RV that you unscrew.
Here is a recent thread on that access:
http://www.forestriverforums.com/for...ml#post1463631
Old 04-11-2017, 08:38 PM   #10
Your bypass for winterization is definitely ON. I did the same thing a few weeks back. No hot water, just luke warm. Sure enough, after thinking about it, the hot water bypass valve was still on. DUH.
mgarland48 is offline   Reply With Quote
Old 04-12-2017, 08:47 AM   #11
Me too. Felt dumb, but happy it was an easy fix.
aeblank is online now   Reply With Quote
Old 04-12-2017, 11:24 AM   #12
Doe
Junior member
Doe
The atteood must have around 55-60 psi to operate I went thru the same thing they changed the heater and said it was working fine but what the rv people are using is the water pump witch puts out 60 psi that is why it works for them so I removed the 45 psi that they put on the rv and ck it it is about 40 psi so I removed it and take a pressure gauge with and ck the parks and most that I ck are around 60 psi and all works great hope this will help
Doe is offline   Reply With Quote
Old 04-12-2017, 12:08 PM   #13
wmtire's Avatar
Doe, there may possibly be some confusion here. What you are describing pertains to the Atwood tankless/on demand type water heater which according to the FR website, your Legacy does have.
Legacy SR 340 Class A Motorhomes by Forest River RV
However, also according to the FR website, the OP has a 6 gallon Gas DSI/Electric tank type Atwood water heater in their Mirada......so flow rate wouldn't be applicable to their problem if they do indeed have that type Atwood.
Mirada Class A Motorhomes by Coachmen RV
It definitely would make it simpler in giving advice if FR used all the same stuff in all their lines.
Old 04-12-2017, 12:30 PM   #14
Chuck.C's Avatar
If you still have trouble locating the valve, try Coachmen support, which has been great in all my needs. The last rep I've dealt with is:
Tonyia Kopsick
Service & Warranty Advisor
Coachmen RV/Class ďAĒ Plant 310
Direct # 574-825-8663
email: tkopsick@forestriverinc.com
2013 Coachmen Mirada 35DL
Chuck and Susan, RIP Toby and Gracie, the greatest dogs.
Chuck.C is offline   Reply With Quote
heater
