I chuckled to myself what did going to church have to do with your trouble shooting? I think you had either a loose connection or a little corrosion on the connectors and the steps you took of unplugging and resetting solved this problem. RVs shake and twist and are subject to moisture so ya you may have to repeat your steps at some later date or maybe not good luck you experience may help others.
Retired Navy
2016 Flagstaff 26 FKWS
