Originally Posted by woo10-210
If you have the garden hose connected to the black tank flush with the hose bib valve open and the pressure suddenly stopped, the hose could suck black water back into the fresh water supply without the check valve.
Probably a rare event on a municipal water supply but imagine what could happen if your home water supply is off of a well and you incur a power outage.
Losing power is irrelevant in this case. There is still a 50-80 gallon pressure tank that would have to fail, and even if it did there’s a lot of water that would have to drain out somewhere before a vacuum could be created that was sufficient enough to start drawing from the black tank. What are the odds of all that happening simultaneously.
Bottom line is if all that happened AND the operator was stupid enough to leave the area during the fill process then they pretty much deserve whatever happens. That’s why there are instructions printed on shampoo bottles.
On the other hand, the odds of the cheap 571 valve leaking water are high in favor of failing.
