Old 07-26-2023, 11:57 AM   #1
Bathroom Faucet
My 2022 Puma Palomino has a double handled 4" centerset bathroom faucet. The faucet spout is so short that you can hardly get your hands between the faucet and the back of the sink to wash your hands. Brushing teeth is difficult as well as you have to lean all the way to the wall practically, as the water runs down the back part of the sink. I would like to replace the faucet with one that has a spout long enough to run water to the center of the sink over the drain. Has anyone else experienced this, and do you have a recommendation on where to get a replacement RV faucet, and what type exactly? I appreciate any feedback.
Rob0702 is offline   Reply With Quote
Old 07-26-2023, 12:20 PM   #2
Go to any home improvement store and pick one you like, nothing special about "rv faucets" other than being ultra cheap.
latner is online now   Reply With Quote
Old 07-26-2023, 12:47 PM   #3
yukongold's Avatar
I had the same crappy faucet and problems. To make matterw worse, it is on the side of the sink, not behind it. Replaced it with this one - 8" spout reach.
https://www.build.com/proflo-pfwsc11...hId=pOqJMpumcL
As latner said, there is nothing special about an RV faucet. On every trailer or boat I've owned, the plumbing was standard 1/2" lines and fittings.
2007 Sierra 2500HD Duramax | ECSB
2012 Rockwood Minilite 2104 - Purchased 08/2012 - Sold 07/2022
2022 SOB 29' 5th wheel - purchased 09/2022; 400w solar on roof; 150w suitcase kit; 206ah LiFePO4; 2k inverter; boondock ready
yukongold is offline   Reply With Quote
Old 07-26-2023, 01:01 PM   #4
Faucet
You'll probably need one of these when installing the new faucet. I would try installing without the extension kit first, then go back to home improvement store if needed. The kit looks like this: https://www.amazon.com/Moen-100818-E...00083Q4IQ&th=1
JoePK is offline   Reply With Quote
Old 07-27-2023, 09:29 AM   #5
Cheap RV Faucet
Thanks to everyone who responded to my thread, and thanks for the good information. I agree that RV faucets are very cheap plastic, and most times installed in a very tight location. It makes me wonder what the designers are thinking when they come up with stuff like this. I'll look into your suggestions and replacement ideas. Thanks!
Old 07-27-2023, 09:51 AM   #6
Kanadian Kamper
kenandterry's Avatar
It’s not the designers…..it’s the budget guys!!!!!
And none of them owns the same RV.
Ken and Terry
kenandterry is offline   Reply With Quote
Old 07-27-2023, 10:07 AM   #7
If you change it to a standard style non RV model
make sure you have some way to adjust the water flow
too much and it will splash all over the place in a shallow sink
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 07-28-2023, 09:25 AM   #8
Bathroom Faucet
Thanks for all of the suggestions and information guys. All they had to do was make a longer spout. I can live with the cheap plastic. It's not like we use the camper every day. But I am going to change is to make it more useable anyway.
bathroom, faucet, roo
