Old 07-03-2022, 10:33 PM   #1
Bathroom leak/washer draining
Hey all,
I am new to RV life and need a little help. I have a Sabre 37FLL with the washer/dryer combo in the bedroom. During the washer drain cycle water leaks from the wall behind the toilet. I am at a full hook up site and my gray tank is open and empty. The water that was in the floor was slightly soapy as well. The first drain cycle produces the most water. Any help would be appreciated.
Jobral83 is offline   Reply With Quote
Old 07-03-2022, 11:22 PM   #2
bikendan's Avatar
Originally Posted by Jobral83 View Post
Hey all,
Moved thread to Plumbing/Water Systems/Fixtures sub-forum since these questions are specific to that subject area and are not General questions.
Old 07-04-2022, 12:24 AM   #3
nvs4602's Avatar
On our Class C motorhome there is a valve you have to open to let the washer to drain. It does not go into the gray tank, it goes straight out to the stinky slinky. Maybe yours is the same.
On our there is 3 valves located where you hook up the dump hose. 1 for Grey, 1 for black tank and 1 for washing machine.
nvs4602 is offline   Reply With Quote
Old 07-04-2022, 12:51 PM   #4
Hey and thank you. I do not have a valve on the exterior. I'll have to pull the washer out to see if the valve is interior. Thank you for the info.
bathroom, drain, leak, roo
