Old 09-14-2024, 02:43 PM   #1
Bidet toilet seat project
I'd like to install one of these https://www.amazon.com/gp/product/B0...PU2MDZS9W&th=1 on this toilet.
Alternatively, is it possible to adapt a real, heated, Toto-type bidet seat to this toilet?
Thanks.
ID:	303939   Click image for larger version
ID:	303940   Click image for larger version
Dieselista is offline   Reply With Quote
Old 09-14-2024, 03:18 PM   #2
Not sure what model toilet you have but I know the Amazon will work. You will probably need to replace the toilet seat as the RV Bidet will raise the seat and as I remember they supply you with a couple of bumpers to raise the front seat.
As far as the Toto goes it depends on you toilet model. Also, you will need power.
2016 Siverback 33IK, Towed 60K+ mile
Old 09-14-2024, 05:25 PM   #3
Pharphr's Avatar
I installed a BioBidet BB2000 in my Rockwood 2442BS. I previously had it in a Keystone Cougar 22RBS. On the Rockwood, I had to elongate the hole in the floor to make room behind the Bidet and the wall. I also ran a power circuit behind the toilet. The toilet model is a Dometic 320 elongated bowl, which is why I had to make room behind the toilet. On the Cougar, the toilet was originally on a diagonal, so I had to turn it to have enough room.
2022 Rockwood 2442BS
2022 Ram 2500
She said "You think you're always right and you never apologize", I said "Sorry, but you're wrong".
Pharphr is offline   Reply With Quote
Old 09-14-2024, 05:34 PM   #4
Pharphr's Avatar
Here are (hopefully) pictures. I wish I had moved it closer to the shower when I made the hole in the floor bigger, but I manage okay.
ID:	303946   Click image for larger version
Name:	Bidet power.jpg
2022 Ram 2500
Old 09-15-2024, 05:44 PM   #5
JMike.VA's Avatar
I added one to ours. It’s not heated. Had to file a little off the back of the toilet to fit, but works great.
JMike.VA
Camper: Forest River Vibe 18RB
Towed by: Toyota Tundra
JMike.VA is offline   Reply With Quote
Old 09-15-2024, 06:05 PM   #6
Thanks.
Your photos appear to be a Dometic 300. That model is listed as not working with the product in the link you provided.
Name:	Amazon_com__RV_Bidet_by_Clean_Camper___Self-Cleaning__Adjustable_Dual_Nozzles___Non-Electric_and.jpg
If the base/bowl of your existing toilet is plastic and not ceramic, it's a 300 and this bidet apparently won't work with it. If you are willing to upgrade your toilet to a 310 with a ceramic base, this thing ought to work.
-Qwkynuf
2003 F150 Supercab 4x4, tow pkg, 3.55 gears
2020 Flagstaff Micro Lite 21DS
Qwkynuf is offline   Reply With Quote
Old 09-15-2024, 06:38 PM   #7
And if it is a Dometic 300 you might want to get rid of it now before it starts to smell/. Just search Model 300 on this forum.
Also, welcome to the forum from the Space Coast of Florida…
Old 10-02-2024, 05:13 PM   #8
Any reason this bidet wouldn't fit the Dometic 310?
https://www.amazon.com/gp/product/B0...1VZD8M3FB&th=1
toilet
