Old 11-28-2020, 04:02 PM   #1
Black/Gray tank fell out, HELP
My black tank fell out of the flimsy "L" brackets. I have a couple of question for any of the experts. 1) the tank came out of the support on one end of the tank, dropping about 3-4 inches, what is the probability of damage to the toilet connection? 2) I jacked the tank back up into the bracket and secured it with more 1 X 4 boards under the tank, so what is an easy way to inspect the toilet flange connection (I don't really know how the toilet connection is made) without taking the entire tank out? 3) If I have to take the tank out, how is the plumbing connected from tank to floor?
Thanks in advance for any help you can give.
Matheny9 is offline   Reply With Quote
Old 11-28-2020, 06:00 PM   #2
Tapex's Avatar
Sounds like you have a decent repair job going on. As to understanding just how this flange is attached to the toilet, I'd say remove the toil and take a look with a flashlight to get a better look at how the tank lines up in the hole for the flange and then go from there.
I'm sure other members may have a better solution for your circumstance
2016 Coachmen Apex 250RLS Ultra Light
2019 Ram Big Horn Sport Longhorn
Tapex is offline   Reply With Quote
Old 11-28-2020, 06:24 PM   #3
Head Rambler
I agree with tapex, take a look down the toilet stack and see if everything is lined up.
Gotta go campin!
Old 11-29-2020, 05:36 AM   #4
Not a repair guy, but what if you filled the tank and checked for leaks?
Rusty
2019 Riverstone Legacy 38MB
Full Paint Merlot/All Options
2015 Black Ford Platinum Diesel F-350 Dually
lcv800 is offline   Reply With Quote
Old 11-29-2020, 06:08 AM   #5
nomad297's Avatar
Rusty
Since the OP appears to already have the underbelly exposed and any fiberglass insulation removed, this would be a sure fire way to find out. It would also serve as a test of the integrity of the OPís new black tank support system.
I wouldnít suggest doing this if the OP has already put the insulation and Coroplast back in place, though. I would do as has already been suggested ó pull the toilet and take a look with a flashlight or, if the toilet doesnít dump directly into the top of the tank, a bore scope.
Bruce
Old 11-29-2020, 02:06 PM   #6
Did I miss a post? I think it would be helpful to know what type of RV this is, i.e., a motor coach or trailer, as well as the year and model.
Forest River Flagstaff e-pro 14fk
Ford Escape Turbo
Sarahcat is offline   Reply With Quote
Old 11-29-2020, 02:33 PM   #7
bikendan's Avatar
The OP's profile clearly shows a 2016 Coachmen Chaparral trailer.
Old 11-29-2020, 02:43 PM   #8
Ours did that the flange at the tank and toilet had to be replaced also
locogk is offline   Reply With Quote
Old 11-29-2020, 03:50 PM   #9
Guess I'm as uninformed as you. I don't see any of this on his post or profile.
Good thing we have a retired hose dragger to politely explain things to us.
Greg 'n Deb
2020 R-POD 195 HRE
'17 Tacoma 3.5L,'07 Tundra 5.7L w/ tow pkgs.
Dirt Sifter is offline   Reply With Quote
Old 11-29-2020, 03:59 PM   #10
If the tank is empty of waste I'd just fill to the brim, even up into the dump tube from the toilet, and see if there are any leaks. This will also test the max weight bearing capacity of your repairs. Better in your yard/driveway than going down the highway.
If waste is still in the tank use a 5 gallon bucket to ferry waste from dump valve to toilet, then do the water test.
Whether or not damage was done will depend on type of connection. If a "slip in" then maybe not. If a stub was spin welded to the tank and a hose/clamp connection made, good chance something broke.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 11-29-2020, 04:04 PM   #11
Garrette's Avatar
Found this. Could be a bit dated.
https://www.sunlineclub.com/forums/f...elp-17689.html
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 11-29-2020, 07:34 PM   #12
Dirt
Click on the Op's name, then on personnel profile, then 'About Me', this shows details on him and his trailer.
Harvey
Harvey9 is offline   Reply With Quote
Old 11-29-2020, 11:09 PM   #13
bikendan's Avatar
Originally Posted by Harvey9 View Post
Dirt
Harvey
It's even easier with the green app. Just tap on the member's green username and their whole profile shows up, depending on how much the member filled out. That's why it's constantly suggested for new members to fill out their profile. So they don't have to keep posting their RV information.
Old 11-30-2020, 11:35 AM   #14
Thanks, Harvey9, much more practical info. Not everyone uses a smart phone, or wants to share access to all the information apps seem to feel they need to help folks.
Greg 'n Deb
2020 R-POD 195 HRE
Old 11-30-2020, 12:19 PM   #15
DustyRoads's Avatar
Just a suggestion since you have it apart you might want to consider replacing the tank sensors with something better for less false readings. There are plenty of YouTube videos on how to do.
Good Luck
2017 Forest River Surveyor 251rks
2016 Chevy 2500HD
DustyRoads is offline   Reply With Quote
Old 11-30-2020, 04:33 PM   #16
DouglasReid's Avatar
I don't see that information listed anywhere in the OP's post. Where did you get that which you state is so clear to you; yet invisible to the rest of us?
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 11-30-2020, 05:43 PM   #17
Wasn't mentioned in his post. Click on "his name", click "view public profile", click "about me".
latner is offline   Reply With Quote
Old 11-30-2020, 06:48 PM   #18
Ya learn something every day o this site!
But the OP should fill out his signature so all that is not necessary. Or many who would have helpful suggestions will not have enough information to help him.
Old 12-02-2020, 10:29 PM   #19
MaPaChoo
Our closet flange (where the toilet meets the floor) is screwed to the floor to keep it secure. The toilet pipe 3" is glued to the flange then runs into the black tank through a rubber gasket. The original gasket was sealed with dicor on the outside not on the mating surfaces. I will tell you it's a bear to get loose pulling it out of the gasket. The pipe extended probably 4 or so inches into The gasket.if you look down the toilet and see tank its probably still in place. I can't tell you about the vent pipe as ours is in a wall. Fill the tank and see what happens. But I think I would make sure it's hooked up to sewer as you may need to dump it fast if there is a leak. Sorry it took so long to respond. I was pulling our toilet apart and wanted to give you the best info I had available. Now ours is a 2007 class c and your in a trailer but manufactures tend to stick with what works good luck
2007 Lexington 283 GTS
MaPaChoo is offline   Reply With Quote
Old 12-07-2020, 08:25 PM   #20
The same happened to me on my 2017 8327SS on both the fresh tank and black tank. Fortunately there was no damage to the flange or vent that I know of. I have used the unit for the last 2 seasons with no issues. Sorry I don't have any pictures readily available of my repairs but I can tell you that they will never fall out again!
Xzena3 is offline   Reply With Quote
black, tank
