Originally Posted by tgomez61
I'll have to give that a try... I think maybe it was just a coincidence that I was flushing the black tank when the fresh water overflowed. I had the city water supply already hooked up... and the previous weekend was primitive camping so I had some water left in the FW tank and the check valve stuck open.
Will drain the FW tank and try hooking up to city water to see if it still transfers...
Still would like to see a diagram of the plumbing for future reference.
You don't even need to drain it (I wouldn't as it may take hours for it to fill up again).
Leave it full, then hook the city water back up and wait.
If water starts dripping out of the bottom on both sides towards the rear (and near the tires)...chances are your water pump's check valve has gone bad!
And you don't have to replace the whole water pump, but just get a brass RV check valve at Camping World or other RV parts supplier, and spend five minutes putting it in and you'll be all set!
This is what it looks like:
