Black tank fitting removal
Any of you removed a black tank fitting that was assembled like this? It appears to be a rigid glue material that was used in this 2018 rig. Both black and gray Tanks used the same material/screw clamp assembly method.
No issues, just wondering how to repair if the need should arrive. I notice the repair parts are essentially press fit into a hole in the tank. That won’t work here since the tank has a flange built in.
