08-23-2017, 07:45 PM
Black tank flush not working
When I try to use the black tank flush, it just pressurizes and doesn't flush. Anyone have a y insights ? It's a brand new trailer.
08-23-2017, 07:48 PM
Jaybejo
My Sandpiper is in the shop right now. Warranty work. I'll let you know the outcome
Jay
08-23-2017, 07:49 PM
Yes installed backwards! Youroo!!
08-23-2017, 07:51 PM
Jaybejo
Mine did work then stopped working. I think it might be the check valve. Not sure where it was so
08-23-2017, 08:20 PM
Jay
08-23-2017, 08:21 PM
Is the check vale behind the hook up? Cause the water doesn't go too far.
08-23-2017, 08:30 PM
I have No idea where your valve is located,Because you have Never said what "Kind ,Make,Model# your unit is! Youroo!!
08-23-2017, 08:47 PM
According to the OP's profile, they have a Vibe TT.
08-23-2017, 08:56 PM
It's a vibe 308bhs 2017
08-24-2017, 12:30 PM
I have a Rockwood Minilite 2109s. Couldn't get the flush to work. Looked underneath and found that the rubber hose from the flush line going into the black tank was too long and whoever installed it just bent the hose in half to get the end connected to the black tank inlet. Cut about 4 inches of hose off, reconnected with no kinks in the hose and it works fine now. Hope this relates to your issue.
08-24-2017, 12:33 PM
Jaybejo
This is the same fix I had. Kinked hose. Forest River is getting too big to care about a quality product any more.
08-24-2017, 12:56 PM
I think I will have a dealer do it since it is brand new and I have the enclosed underbody. Probably void some warranty.
08-24-2017, 01:32 PM
It's not so much that they don't care about quality...it's their production schedule and the way they run the manufacturing facility.
When they get the required number of units produced for the day, the production crew can go home. So they run and work as fast as they possibly can. If they get done in 8 hours, they go home. If they get done in 5 hours they go home.
What would you do?
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
08-24-2017, 01:33 PM
What would you do?
This applies to the Cedar Creek facility. I'm not sure about the 50 other plants.
08-24-2017, 02:28 PM
What would you do?
Do it in 6 hours correctly
08-24-2017, 02:34 PM
What would you do?
Work slower and draw some over time.
08-24-2017, 05:05 PM
Black tank flush
My flush also appeared to not work; found out that the hose was kinked when installed at factory. Oh well.
08-24-2017, 07:36 PM
You may have a kink in the hose. That was my problem. I had to trace my water line inside a panel where the input is and straighten the hose . Works great now.
08-25-2017, 08:24 AM
black flush
my check valve went bad, where the hose hooks up 3 screws slide it out unscrew , install new one, there cheap
08-25-2017, 09:16 AM
Jaybejo
Ya apparently it was a kinked hose.
I could not find my check valve.
From the connection point in the service centre it go to the front of the 5er (disappeared somewhere) then goes back to the tank. Not sure where the check valve is.
Jay
