Old 08-07-2022, 11:06 AM   #1
Black water cross connect
I recently became aware of a person flushing their black water tank with a hose from the potable water tap at a dump station. The potable water tap is a self draining hydrant type for frost protection so when shut off it drains including back flow from the attached hose. The tap is signed for potable water use only. This could be potential for contamination, have others encountered this?
Seeking Adventure is offline   Reply With Quote
Old 08-07-2022, 11:09 AM   #2
Yep. And people do it at full hookup campsites as well. It's a good idea to wipe down any spigot you are going to connect your trailer's freshwater system to with a sanitizing wipe.
NavyLCDR is offline   Reply With Quote
Old 08-07-2022, 11:14 AM   #3
NMWildcat's Avatar
If there is a tap intended for potable water close enough to a dump station, you have to realize someone will use it to rinse black tank and sewer hose.
Most taps near dump stations I use have a sign saying not to use them as a potable water source. Not that anyone pays attention to that either
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 08-07-2022, 11:41 AM   #4
Homebrew's Avatar
I see a lot of people using the fresh water at sites to rinse the sewer hoses.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 08-07-2022, 11:46 AM   #5
bubbles's Avatar
Excluding sewer dump hose rinse there is no way to "cross contaminate" the black holding tank factory installed cleanout provision.
Old 08-07-2022, 11:48 AM   #6
You mean because of the vacuum breaker valve found in the line to the black tank flushing connection on the tank?
Old 08-07-2022, 04:22 PM   #7
Thanks for all the info. I still think that it is best to error on the side of caution & stay safe. There is a reason why most potable water taps are kept well away and signed.
Old 08-07-2022, 09:45 PM   #8
x2. Wiping down is a good idea. In addition to people, bugs and critters have been known to drink from the water left over in water spigots.
Cross contamination is one reason we only drink gallon water from home or the store. People on vacation sometimes don't think...
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
black, black water, water
